plymouthcolt's Avatar
Do 3.2 intake runners use gaskets?
I need to remove my right intake runner to fix an oil leak at the rear.
Do the intake runners use gaskets to attach to the manifold?
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 03-31-2006, 12:31 PM
Somewhere in the Midwest
MotoSook's Avatar
Yes, two per port which sandwich the plastic insulator.
Old 03-31-2006, 01:01 PM
Do you think it would be ok to reuse them? I just need to get to the breather gasket.
Howard
2003 996tt
Old 03-31-2006, 04:35 PM
Very common place to find intake leaks....often urged to replace..
They get "sucked" into the intake "airstream"...(or so it appears) once you discover an intake leak.
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-31-2006, 05:15 PM
Jeff Alton's Avatar
NO, do not reuse them. I also recommend you relpace the "plastic" block between the heads and the manifold. They can get "out of shape". All of the parts required are really inexpensive....\
Cheers
www.turn3autosport.com
Old 03-31-2006, 08:16 PM
