Hi everyone!!
All of a sudden, my porsche (911 from 1988) behaves very weird, here's the symptoms: -When started, it idles at about 200-300 rpm, very unsteady. -If I give it some gas, nothing really happens, but I I give it gas for a little while it slowely (and very unsteady) builds up to higher revs. -when reached 2000-2500 rpm, everything seems to work fine (and sounds fine), however, as soon as I release the throttle it slows down again to 200rpm, and when driving, if ever below 2000rpm, it starts to sound funny, just like it doesn't get enough fuel. I have changed both fuel pump relays, but it didn't make any difference. Now what could this be?? I have seached some in the forums but I haven't found anything. Many thanks!! |
carb cleaner..
I have read that spraying something called "carb cleaner" somewhere might help..
I'm not english, so could someone explain to me what "carb cleaner" is and where to spray it? Is there any risk involved in spraying carb cleaner as a (temp. ) solution? THANKS! |
Did anything lead up to the issue? Is it down on power until 2k rpm? What happens after 2k? Does it have full power or 80% power, etc??
I think it could be a number of issues, we need more informatoin. When was your last tune-up? The way I see it, the problem(s) could be air, fuel, compression or spark related. Can you eliminate some of these potential causes: compression? bad spark plug wire (s) bad cap and rotor mass air flow sensor - maybe broken or bad contacts vacuum leak. Idle control valve - seems unlikely. bad injector(s) bad fuel pressure regulator
1971 RSR - interpretation Last edited by DW SD; 04-03-2006 at 05:11 PM.. |
I had exactly the same issue! Turned out to be a dud AFM.
Once I replaced that, everything came good, for a short while, then my damn Fuel Pressure Damper tore the internal diaphragm and bled fuel into the intake, causing the same symptoms, but this time it was flooding the engine (black smoke everywhere). Check the AFM, and if possible, replace your AFM with a known good one to test it out. Also, hook up a fuel pressure gauge to your fuel rail to verify you are getting 36-38psi at idle. It may well be your fuel pressure regulator, or damper.
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Thanks a lot both of you!
I might try changing the AFM myself, otherwise I'll just bring it in to the mechanic. THANKS! /M |
miakki
I don't know the chemistry of carb cleaner but it is a spray solvent that can be used on the inside and outside of carbs that disolves old fuel buildup. Sometimes good for cleaning jets, the outside of carbs, etc. I doubt this is your solution, especially if the problem was sudden. |
Autodidactic user
Re: carb cleaner..
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
Somatic Negative Optimist
Do Carreras have 2 pump relays?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Thanks!
Well, then I guess carb cleaner isn't my solution.. It's a turbo, which has 2 pump relays. Thanks!! /M |
Ah, yes, turbos have 2 relays.
That wasn't clear from the beginning and is a different ball of wax. Turbo-owners: Chime in.
