Autodidactic user
David E. Clark's Avatar
Anyone speak German?
I bought some old (1972) porsche repair documents and found one written in German. It contains two graphs.
One is labled "Unterdruckverstellinie" with "Unterdruck mmHg" on the X axis and "Grad-Verteilerwinkel" on the Y axis.
The second is labled "Fliehkraftverstellinie" with "n-Verteiler" on the X axis and "Grad-Verteilerwinkel" on the Y axis.
According to the German/English dictionary I found on the web, "Verteiler" means "distributor" and "Unterdruck" means "under-inflation." The other words (phrases) did not get a match in the dictionary.
I'm thinking that these are the advance and retard graphs for the distributor. Think I'm close? My scanner broke or I'd post a scan.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 04-05-2006, 05:37 PM
SirAndy's Avatar
Re: Anyone speak German?
not just close, but dead on!
Andy
Unterdruck = negative pressure/vacuum
Fliehkraft = centrifugal force
Verteiler = distributor
Winkel = angle
Grad = degree
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 04-05-2006, 05:38 PM
Autodidactic user
Thanks Andy. What do the words not in the dictionary ("Unterdruckverstellinie" and "Fliehkraftverstellinie") mean?
Since "Unterdruck" means "under-inflation," is this graph, the one labled "Unterdruckverstellinie," for retard and the other one labled "Fliehkraftverstellinie" for advance. Is it that simple?
Thanks again
Old 04-05-2006, 05:45 PM
Wider is Better
wholberg's Avatar
And mmHg is millimeters of mercury.
760 mm Hg = 1 atmosphere = 14.7 lbs/sq. inch at sea level.
Wider is Better
Old 04-05-2006, 06:05 PM
SirAndy's Avatar
Thanks again
"Unterdruckverstellinie" and "Fliehkraftverstellinie" refer to the curve for each on the chart. (Linie = Line, in this case the actual line drawn on the chart) ...
as to which is used for advance and which is used for retard i'm not sure, "Unterdruckverstellinie" is obviously driven by vacuum while i would assume "Fliehkraftverstellinie" is driven mechanically by centrifugal force ...
Andy
Old 04-05-2006, 06:13 PM
Now in 993 land ...
aigel's Avatar
Unterdruck means vacuum
Fliehkraft means centrifugal force
Unterdruckverstellinie = Vacuum advance curve
Fliehkraftverstellinie = Mechanical advance curve
Grad=degree
Verteiler=distributor
Winkel=angle
Grad-Verteilerwinkel = advance in degrees
Viel Spass!
George
81 SC (sold)
Old 04-05-2006, 09:34 PM
Michael Delaney wanna-be
Netspeed's Avatar
Here's a great website that will translate anything to anything:
http://babelfish.altavista.com/
88 Carrera Cab
C.R.A.P. Gruppe Member #7
Old 04-05-2006, 09:58 PM
Now in 993 land ...
aigel's Avatar
Yeah, netspeed, it will put translators right out of business! But it indeed can help you at least gather what the subject of that foreign blurb is about.
George
81 SC (sold)
Old 04-05-2006, 10:02 PM
SC Schrauber's Avatar
Mein lieber Junge! Bei dieser Anzahl an deutschen 911-Fahrern sollten wir einen Stammtisch aufmachen!
Wow! With these many German 911 lovers we should establish a Stammstisch!
Frank
81 SC, www.frankschroeter.com
Old 04-06-2006, 02:42 AM
911scNorway's Avatar
Hello
"Unterdruck means vacuum" is almost correct, as i understand with my limited German
Unter = Under
Druck = Pressure
Therfore Unterdruck means Underpressure ( relative to 1 atmosphere or 1 Barg) hence Vacuum.
Mark
996 C4
911 SC ex
An Englishman in Norway (yes it´s cold)
Old 04-06-2006, 04:01 AM
SirAndy's Avatar
i propose the Speisekammer for the SF Bay Area ...
Old 04-06-2006, 09:54 AM
Autodidactic user
I think Babelfish needs a few "tweaks" before it puts any translators out of business. When I typed in "Unterdruckverstellinie" and asked for an English translation I got:
That really wasn't much help!
Old 04-06-2006, 11:07 AM
SirAndy's Avatar
that's because we germans love to clump a bunch of words into one. the bablefish engine couldn't find a exact match for the word, so it simply returned your input.
if you had split it up into it's original 3 words
Unterdruck
verstell
linie
you would have gotten "Negative pressure adjust line" which is actually a pretty good translation ...
just take "Fahrvergnügen" which losely translated means "the joy you get out of driving a car" ...
why waste a whole sentence when you can get it all squeezed into one word!
Andy
Old 04-06-2006, 11:41 AM
Originally posted by SirAndy
Unterdruck
verstell
linie
Andy [/B]
Lustige Sache das!
translating"Negative pressure adjust line" back gives:
"Negativer Druck justiert Linie"
Old 04-06-2006, 01:01 PM
exponence's Avatar
Na denn Prost
Old 04-06-2006, 01:19 PM
Babelfish is not really good...there are a number of English-German translation web sites and services that are infinitely superior...
Even the Google language tool is better....
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-06-2006, 01:23 PM
Even the Google language tool is better.... http://www.google.com/language_tools?hl=en
here's one---> http://www.linguatec.net/online/ptwebtext/index_en.shtml
another---> http://translation.langenberg.com/ that uses 5-6 variations that can be used...to chase down the inevetable subtleties.
- Wil
Wil Ferch
Old 04-06-2006, 01:25 PM
heiliges blechle!
My father-in-law used to say:
"heiliges blechle!"
When something irritated him. Now I think it could also describe a Porsche!
'84 M491 '07 Silverado
'75 Suzuki GT550 2-stroke triple
'02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train
Old 04-06-2006, 01:26 PM
Autodidactic user
Got my scanner working again. Here is the document we've all been talking about.
You guys were right on. Here are the same graphs out of the 1972 Factory Workshop Manual. Slightly different scales are used, but the information is the same. Thanks. This wasn't some secret German formula I've been missing all these years!
Old 04-06-2006, 02:03 PM
[/B]
No.
The secret German formula is:
Leistung = Arbeit / Zeit
Work quicker!
Old 04-07-2006, 04:13 AM
