Sunroof problem detected.
looks like one of the plastic guides that attach to the cable is broken-see pix- the cables themselves and everything else looks good. Does anyone know if i can just buy the plastic guide on the cable rather than replacing the whole cable? i checked here at pelican, but found this piece sold w/cable as the whole assembly.
If so, do they have metal versions? best, paul. http://forums.pelicanparts.com/uploa...1144201873.jpg |
Sunroof cable.....
I suspect you will have to replace the whole cable/guide as a unit. While you are in there, go ahead and do both sides. You will have to buy the later style cable units and do a little filing to make them fit the guide rails in your car. A Dremel tool makes this job much easier.
Good luck! |
Re: Sunroof problem detected.
Mike |
ok, great...thanks again...and yes i have a dremel to make life a little easier...i'll be in touch with updates
| All times are GMT -8. The time now is 11:48 PM. |
