Sunroof problem detected.
looks like one of the plastic guides that attach to the cable is broken-see pix- the cables themselves and everything else looks good. Does anyone know if i can just buy the plastic guide on the cable rather than replacing the whole cable? i checked here at pelican, but found this piece sold w/cable as the whole assembly.
If so, do they have metal versions?
best, paul.
84 R5 T2
04 Suby Outback
"it's a mystery, wrapped in a riddle, inside an enigma" Winston Churchill.
Old 04-04-2006, 06:52 PM
fred cook's Avatar
Cool Sunroof cable.....
I suspect you will have to replace the whole cable/guide as a unit. While you are in there, go ahead and do both sides. You will have to buy the later style cable units and do a little filing to make them fit the guide rails in your car. A Dremel tool makes this job much easier.
Good luck!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 04-04-2006, 07:09 PM
Re: Sunroof problem detected.
The replacement cables are metal that require very minor filing to fit. See this article in the Pelican tech section for more information with photos.
Mike
Mike
'68 911 # 11830241
Old 04-04-2006, 07:39 PM
ok, great...thanks again...and yes i have a dremel to make life a little easier...i'll be in touch with updates
84 R5 T2
04 Suby Outback
Old 04-04-2006, 07:58 PM
