avendlerdp's Avatar
Where do I buy weld on rear sway bar drop link balls?
I am adding a rear swaybar to a car that never had one and need to weld on those ball joint things to the banana arms. Where can I buy them?? Early steel arms by the way.
Thanks,
Alex
1972 Porsche 914 Project
2000 BMW M5
1973 Aermacchi 350
Old 04-04-2006, 07:28 AM
ttweed's Avatar
I would like to source a pair of these, too, so I'm bumping this back to the top.
Anyone?
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 04-04-2006, 05:12 PM
You can still buy them from Porsche.
The part # is 901 331 571 07
They cost $35.94 each
Mark
Old 04-04-2006, 06:04 PM
PRO Motorsports
Tyson Schmidt's Avatar
We tried. They are NLA from Porsche.
Unless they started another batch.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 04-04-2006, 06:08 PM
That's strange I just purchased 2 on Feb 27th
Mark
Old 04-04-2006, 06:14 PM
It seems like it would be available from other sources as well; I'd guess it is a standard size ball and socket coupling. I just did a quick search on McMasterCarr, but, not knowing the exact size or description, was unable to find anything.
Shouldn't be too tough to whip one out on the CNC lathe and have it hardened, but I'd guess you can find them at an industrial supply house for less than ten bucks each.
If anybody can snap a quick picture and put a caliper around the O.D. and tell me what size it is (+/- a couple of thou would be good), I'll check with some different suppliers and see what I can come up with.
I've got a '72T that came from the factory with no sways, so I've been contemplating this (and gathering parts for my suspension refresh) for a month or so.
Jim
EDIT: Looks like you can buy them from our host.
Old 04-04-2006, 06:36 PM
Just a search on Pelican using the above part#:
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?please_wait=N&forumid=&threadid=&command=DWsearch&description=901+331+571+07&I1.x=9&I1.y=8&FILTER_TECH=ON&FILTER_SUPP=ON&FILTER_ACCE=ON&FILTER_CARE=ON&FILTER_STUF=ON&FILTER_PERF=ON&FILTER_MISC=ON&FILTER_GADG=ON&FILTER_TOOL=ON&FILTER_APOR=ON&FILTER_PORS=ON&FILTER_911E=ON&FILTER_911M=ON&FILTER_911L=ON&FILTER_996M=ON&FILTER_356M=ON&FILTER_9144=ON&FILTER_944M=ON&FILTER_928M=ON
Part Number Search:
Description Part Number Price More Info
HINGE PIN
- This is a special-order, non-returnable, part
(availability and shipping charges may vary).
OEM-90133157107 $44.92
Could this be it?
Old 04-04-2006, 06:41 PM
Yes on my receipt from Porsche they call it a hinge pin #901 331 571 07
I actually have them so it is the correct part.
Mark
Old 04-04-2006, 06:48 PM
PRO Motorsports
Wow, that's great news!
We tried to get them a while back, and they were NLA.
But Porsche has been very strange lately with things becoming unavailable, then available, then not. Early dashes for example. I Hope you guys are right. I'll get my parts guy to order some up for me tomorrow.
2004 GT3
Old 04-04-2006, 07:00 PM
avendlerdp's Avatar
I just ordered some from Pelican so let's see if I get them and they are right. Thanks for all the help.
2000 BMW M5
1973 Aermacchi 350
Old 04-04-2006, 07:37 PM
Elombard's Avatar
Why not go with The sways that mount to the spring plate?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 04-04-2006, 07:46 PM
avendlerdp's Avatar
I already have the stock rear bar and don't want to buy another. I am a cheapo!
2000 BMW M5
1973 Aermacchi 350
Old 04-04-2006, 07:54 PM
Zeke's Avatar
I switched over to those on the SP to get adjustable links. It hung down too low for my liking. But, it was better than the plastic cup bushing that slipped off when I really pushed it and hit any bumps like a berm in a corner.
I think the later bolt through type for the swing arm would be better. Can these be installed on the steel arms? Are there little shorty adjustable drop links for that setup? That's the way I'd like to go next time.
Old 04-04-2006, 07:56 PM
Elombard's Avatar
I was wondering the same thing. I thought I read one time that you could retrofit the later swing arm attachment to the early arms. I could not see a way to get it off my steel arms, maybe they are removable on the 74 alum arms??
Zeke are you saying you can take a stock rear bar and switch to SP mounted links to get adjustable links? Or do you have to change the bar also?
I am a cheapo to, I thought you were wondering if there was "any way" to mount a bar back there period :-))
Old 04-05-2006, 04:14 AM
Zeke's Avatar
NO bar change. Just switch over the drops to the differnent style. The "clamps" are what hung down low below the bar. I adjusted the links to be short as possible; it's still not the opitimum set up.
Old 04-09-2006, 09:50 AM
