cycling has-been
PET help please
can anyone give me the pn for the front torsion bar cover/protector. (3-bolts)
My 930 once had protective bars welded to it and I don't know if it came that way, or the prior owner had them welded on. I'm not too crazy about the Weltmeister 'skid plates' that require new drilled holes. thanks Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Possibly 911 341 037 00 Protective Bracket (left) and 911 341 038 00 (right).
If this is the correct part, it looks like they were superceded with 02 for the last 2 digits instead of 00 for both sides.
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
I show a part number of 911 341 037 00 for the left side,
901 341 159 00 for the right side. It lists a separate part number for the right side labelled "overseas", probably some variant for a special towing hook or some such thing. Hope that helps.
Bruce Herrmann 97 C4S '04 330i '08 Cayenne S '07 4.8 X-5 |
Insert Tag Line HERE.....
911.347.037.02 / left
901.341.159.00/ right Thats what it lists for standard. It also lists a 911.347.038.02/ M /right for the right side with a suffix of 'M' which means optional equipment. Dont know what would be different about them, unless there is something that might attach to the one on the right side?? Someone else might know, but i think i would go with the 037/ and 038s and also, 930.341.160.00/ spacer/ 1 each side. |
cycling has-been
wow, thanks gents
Bill K
