- Self Moderating -
Has anyone ever taken their stone guards off from rear wheel arches??
I need remove one of the black plastic stone guards that cover my rear wheel arch to get access to remove my broken rear torsion bar. Has anyone ever taken their originals off? Just wondering if I might find that it is going to damage the finish...
Has anyone ever just cut around the 'plug' (not proper term I am sure) to gain access this way? I am concerned over moister....
Any thoughts?
Tim
Present: 57 Intermeccanica Speedster Ivory on Brown
Past: 85 911 Carrera Coupe Silver on Black, 57 Intermeccanica Speedster White on Tan
Old 04-06-2006, 10:42 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Cut around the plug.
Removing the whole guard would be a major PITA. If you do, I would assume that a heat gun or maybe hot soapy water would help, along with patience, patience, patience.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 04-06-2006, 10:50 AM
bigrubberjeep's Avatar
I agree. besides if the finish doesnt look perfect it will get recovered with a new stone guard right?
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 04-06-2006, 10:53 AM
I just cut around the hole. Still looks good even with the semi circle missing.
I guess if you want to keep the look you could paint the torsion cover black while its out.
Howiee
1983 euro sc
Old 04-06-2006, 10:55 AM
If you simply do this to remove the torsion bars..use a hair dryer on the lower-most portion and peel back...so the hole "hatch" is uncoverd and can be removed. Then reglue the bottom portion after your torsion-bar repair is done and the metal cover is back in-place. Don't take the whole black cover off.
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-06-2006, 11:24 AM
- Self Moderating -
Thanks for the feedback guys. I am going to ponder this.....
Tim
Old 04-06-2006, 02:17 PM
I've replaced mine a few times. The cutting idea usually doesn't work out great. I leaves too many edges for dirt to get under and eventually you will have an edge lifting. Better to use a heat gun or hair drier and warm and pull the guard up and then replace. They actually come off pretty easy.
Old 04-06-2006, 07:09 PM
- Self Moderating -
Thanks for your input. I was thinking the same things about cutting. I don't want to accidently cut into the paint or have lifting. I will let everyone know how it goes.
Tim
Old 04-07-2006, 08:14 AM
vash's Avatar
i was just there, the sticker on my car didnt stick to the uneven plugs that well anyways. i found that i could peel it up, easy and push the plug out. i ended up changing them out, and a hairdryer, warmed them up enough that it didnt mess up a thing yanking them off. amazing how new ones look way good, and waxed over ones, look like crap.
poof! gone
Old 04-07-2006, 10:10 AM
