Crotchety Old Bastard
Hood Fallin' On Your Head? My Fix.
Hey I was on a roll tonight so I just kept going (see the CIS Hard Cold Start thread).
My GT2 tail is very heavy, too heavy for one old shock to hold up. I tried the dual shock setup and found it pulled so hard on the one corner of the decklid that it was warping it up and looked uneven. So I figure this needs to be balanced out. With about $5 worth of hardware I put in a second shock where it needs to be. Now my hood closes even and opens easy. No more hood getting stuck shut. (I'll paint it later, once everything is proven worthy to stay put)
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
What about the hard penis looking thing that keeps poking me while bending over the engine? Did I just say that?
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s |
Designer King
Rarlyl8 is definitely on a roll!
Austin, !?!?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
I've often said the dual-shock arrangement on the driver's side is a "kludge" fix and should be avoided...for the reasons stated here.
Most cars already have the brackets installed on the firewall side. To do a real nice "factory" look...you can use a mating right side hinge from a Turbo to complete the picture..... - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
You should make kits. Very nice. If not you, Sherwood, you listening?
Great work....My 9-iron in the trunk looks easier though.
Hey I passed though Huntsville last Saturday. Made a quick pass though the Wheels and Keels drive in Nashville. Then on to the GA Porsche race club at Road Atlanta.
Deutsche Fahrzeuge 78' 911SC 03' 325I BMW 03' KTM 450sx 05' S2000 (daughters) Last edited by emcdan; 04-06-2006 at 08:01 AM.. |
"You should make kits. Very nice. If not you,..."
Zeke, Rarly's bracket mimics the turbo's bracket and it provides even upward pressure as it opens and closes. However, as Wil says, the factory turbo bracket performs the same job. However, if someone wants a simpler solution, there's always the support tube method (no gas to leak, no gas strut to replace: I think Pelican carries these now (or at least the trunk version). Sherwood www.seinesystems.com |
She/Her
The problem with those hard struts is that they dont support a whole lot of weight. I have one and it will not support my turbo tail without the support of the gas shock along with it.
Gwyneth *she/her 1995 993 Guards Red 1984 911 Targa with a G50 (RIP) |
I figure anyone with the minimal ability needed to install an "L" bracket and drill a few holes doesn't need a kit, and those lacking that ability wouldn't know what to do with one anyway.
I also found out with my 930 Air Filter "kit" that nobody wanted to pay for one, even at $25. They wanted the part numbers. Hey, this ain't Rocket Science (and beleive you me when you live in Huntsville you get to know what Rocket Science really is) so I gave out the part numbers. I still get e-mails wanting those part numbers. So here you go. Ready? The "L" bracket is the glide hinge for a pocket door, the bolts are 6mm locating and 10mm fixed with nylon nuts and washers for ease of shock movement. Hinge plate is 1/4" aluminum with 10mm holes for adjusting the 6mm locating bolts (so both sides line up evenly). That's it. Cost about $5 and 30 minutes or so. Works fantastic so far.
Fat butt 911, 1987 |
Detached Member
Don't have a pic, but before I bought a Turbo right hinge for about $30 from another Pelican, I enlarged the hole in the bottom of the "goosenech" of the right hinge in my 84 and put in a hardened bolt and double locking nuts with a strut from Pep Boys to the existing right side strut mount on the firewall. Worked great, had to try several sizes of strut, but none opened up the deck lid completely, about 90% open. I ended up replacing with the Turbo right hinge because it looked to me that if the hardened bolt sheared (not likely) it would allow the strut to jam through the deck lid A/C condensor. I think that may be why Porsche didn't go for that design.
Hugh |
great work, rarly..
![]() ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
The Stiffy
This sucker has rammed me hard many times. It even pulled out hair and caused blood loss. Think I guess I will change my name to Roger.
Here's my bad stiffy What were you guys thinking???
sorry, because you wrote bunch of "pennis", "poke me while I bent over"...
hard penis looking thing.... you mean the drop light hangar!!
a little of this + a little of that |
ahhhh yes...another episode of "Brokeback Pelican"
sjd
Porsche sold, moving back to muscle cars for a bit. |
I kinda wondered about your orientation as well Austin, wasn't painting a pretty picture. Glad you cleared that up.
That hood latch "penis" has torn my skull a few times as well. I very seriously thought about throwing the SOB in the can and adding hood pins.
Never thought that hood pins would help hair loss...
Slumlord
Here's my fix, made from nylon. I just clip it on the strut rod when I'm doing any work.
I'm going to add a velcro strip or a cable to store it near the strut. Last edited by Porsche_monkey; 04-07-2006 at 09:52 AM.. |
