I need to know what part(s) are making my car do this
I've gotten my idle smooth again (though i will still need to get the idle mix and speed correctly set) but my start up worries me.
Here is what is happening: 1. start the car 2. engine sounds and feels rough for about 2 - 5 seconds (almost like its missing) or waaayyyy to rich - no black smoke though) 3. then all of a suddend it revs up to1200 rpm or so and is smooth. 4. from this point on no real problems. What components come into play right when the key is turned? |
btt
Get the mix set and see if that affects matters before you tear your hair out over it...
ianc |
I wonder if you have full fuel pressure immediately upon startup? Can you run the fuel pump for 5-10 seconds prior to startup and then start the engine as normal?
OR There is a test port for fuel pressure on the driver's fuel rail. Can you hook something to this and test the pressure? |
| All times are GMT -8. The time now is 03:00 PM. |
