965 Calipers - bolt holes
Bill,
Please could you confirm whether the drill hole locations/dims as indicated on Kevin's template for the 993 rear caliper are equally applicable for the 965 rear caliper? Thx Martin Gibson 911SC 3.6 |
Yes, that sounds like the # I posted, all of the small Brembo calipers(944/951/964/993) would want the same measurements for mounting on 911 rears.
Make a cardboard template before drilling just to make sure.
Bill,
Thanks for the feedback. It looks like I have tracked down a pair of 'second hand' black 965 rear calipers and was wondering whether you had a feel for a fair US market value? Martin Gibson 911SC 3.6 |
I paid $250/pair for the last set I bought ~4yrs ago, haven't seen another set since.
See ebay 4618232177 for a full set of 965 calipers.
The fronts appear to be 993/S4 calipers that were also used on 965s(they may also be black Big Reds, I can't see well enough to tell)
The backs appear to be the correct 965 rears You can use both front and rear sets of calipers, but neither set of rotors. £495.00 might be ok if you can use everything but is expensive if you only want the rear calipers.
I note that the full set of 965 calipers/discs/pads are back on ebay UK(4630591512) but the starting price has now been reduced to £350 - may be of interest to someone.
