Dave Taylor's Avatar
Alternator Connection Help Needed
I just bought a rebuilt Bosch and an external regulator to replace my old units on my '74 911 because I was only getting 12.54 volts at the battery and couldn't keep it charged.
I labeled the wires as I removed them from the old alternator and here's the list:
B+ (2 red wires, one large, one small)
D+ (small blue wire)
DF (small black wire, quick connect)
D- (2 small brown wires, quick connect)
The DF and D- wires actually connect to the same place at the bottom of the old alternator.
The rebuilt Bosch has the following connections on the back:
B+ (post)
B+ (post)
D- (post)
D- (post)
+61 (post)
DF (quick connect)
So I can connect my labeled B+ wire and connect my labeled DF wire.
Should I connect the D- to the D- post even though they were together on the old alternator?
That leaves me with the D+ (small blue wire) and I don't know where to connect it. I did a search and read lots of posts and am getting the idea that the D+ on my old unit might be the same as the +61 on the new alternator.
Anyone know for sure? I wouldn't want to make a mistake and wire it wrong. I can post pics if that will help.
Thanks, Dave
Dave Taylor
1974 911 Coupe 2.7 Guards Red/Black Trim, Tbitz EFI, MSD
1974 Super Beetle Sun Bug
1959 356A (sold)
1954 Hudson Hornet Project For Sale
18 Years In Storage 1974 911
My Car in the Pelican Gallery
Old 04-13-2006, 02:53 PM
bump...
Dave Taylor
1959 356A (sold)
Old 04-13-2006, 04:53 PM
Dave Taylor
1959 356A (sold)
Old 04-13-2006, 04:58 PM
Surely there has to be somebody out there that's solved this problem......help me...help!!!
Dave Taylor
1959 356A (sold)
Old 04-13-2006, 05:32 PM
bump...
Dave Taylor
1959 356A (sold)
Old 04-13-2006, 07:09 PM
Early_S_Man's Avatar
Porsche Crest
Dave,
That is a rebuilt 70 Amp [980 Watt] Motorola/SEV Marchal alternator, not a Bosch! Your fan housing will need to be machined 9.3 mm deeper to accept the larger alternator, or you will need to get a '75 or later housing.
You need to wire the two brown wires to case ground studs labeled D-, and the blue or green-faded wire to the D+/61 terminal. The warning lamp lead is usually labeled D+/61 on most schematics ... as in the following excerpt:
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-13-2006, 08:09 PM
Porsche Crest
Warren Hall, Jr.
Old 04-13-2006, 08:31 PM
Thanks Warren!
I think I'll keep the alternator and have someone machine the housing so it fits properly. Thanks for the wiring diagram, too!
Dave
Dave Taylor
1959 356A (sold)
Old 04-14-2006, 08:03 AM
