Licensed User
pinch clamps for fuel injection hose
What do you guys think? Are these a better alternative than the factory worm drive clamps for fuel hose? These were good enough for the fuel hose on my MFI motor, so they should be good enough for Motronic pressures, right?
Schleprock
Yes. Use the single pinch because they have a slip-fit type of arrangement, opposed to the double pinch which do not. The slip-fit allows more uniform clamping than the doube crimp IMO.
Also get the crimp tool. It works good. McMaster Carr rocks, don't they? Pegasus racing makes a good point about oetiker crimp clamps
Kevin L '86 Carrera "Larry" |
