-   -   993 Brake Upgrade - Whos using 7x16 fuchs (http://forums.pelicanparts.com/porsche-911-technical-forum/277412-993-brake-upgrade-whos-using-7x16-fuchs.html)
Jcon 04-15-2006 04:42 PM
I read that to use the 7x16 911 offset fuchs you would need a 1/4 inch spacer. I just finished putting on my 993 on the SC and while I don't have a spacer it looks like it would need to a lot more than 1/4 inch. Anyone out there actually done this with a true 911 offset fuch.
Also interrested if anyones using 951 offset 7x16 without spacers. My set up uses a 309mm rotor.
Jeff
don911 04-15-2006 05:00 PM
Not exactly the same but I'm using 951 7's on the front with 930 brakes. I have 911 7s on the rear with 5mm spacer. The fins have been filed on the calipers.
jester911 04-15-2006 05:15 PM
You need to get the skinny from Bill Verberg. He is the brake guru here.
Jcon 04-15-2006 07:28 PM
Bump for the west Coast
peehonix 04-15-2006 07:58 PM
951 fuch's
I have used 951 7x16 wheels on my 911 with the 993 brakes and the large Coleman rotors without spacers. Bolt-on fit. I have a set for sale if your interested.
I also have a set of 951 8x16 fuch's on ebay right now.
hmd 04-15-2006 11:13 PM
Jeff,
I am using 951 16x7 with 309 Coleman 2 pc rotors from ProBraking. It's a tight fit but a fit nevertheless.
