| Registered |
				Valve cover studs
			Just adjusted my valves this weekend and seems like more valve cover studs than last time unscrewed when i took the cover nut off.(Last valve adjustment, seems like only 2 or 3 studs came out and this time it was 4 on one side and 3 on another.)  I used a vice grip to get the nuts off the studs (some of which were rusted on the studs), and simply screwed them back in to finish the job. Thinking now, should i have used loctite or something to keep them from backing out? Anyone else have this problem?
				__________________ '79 930/934 replica 80 RSR-look(Now in Sicily) 914/6 2.7 (Projekt 908/3) 1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW D-Zug Produkte/D-Zug.com | ||
|  01-30-2006, 04:27 AM |
| Registered Join Date: Oct 2001 Location: San Carlos, CA US
			I never had one come loose, you should have loctited them back in.
				__________________ Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 | ||
|  01-30-2006, 05:20 AM |
| Registered Join Date: Jul 2004 Location: Philadelphia
			I had 12 come out the first time I did mine - I cleaned them well and used loctite when I put them back in.  Generally, I found that it was almost impossible to use vice grips to take the nuts off without buggering up the stud- I actually had to replace a few studs  when I tried that method first.  I ended up putting two bolts on the other end, tightened the bolts by hand as hard as I could, put the double nuts in the vice and used a socket to pull off the stuck one on the other end - worked like a charm and didn't leave any scarring.
				__________________ Cory H 85 Carrera | ||
|  01-30-2006, 05:45 AM |
| Registered Join Date: Feb 2004 Location: Stoney Creek, Ontario
			I had the same problem today. One question I have is how do I put the studs back in? Can they be threaded back in by hand and rely on loctite to hold them in place? Thanks in advance ........... Randy
				__________________ 83 911 SC Coupe ''Sunroof Delete'' Are we having fun yet ? | ||
|  04-17-2006, 06:06 PM |
| Now in 993 land ... |
			Randy: Put two nuts on there and fasten them against one another. Then use a wrench to screw the studs back in. Yes, use red loctite to reinstall. George | ||
|  04-17-2006, 06:42 PM |
			I threaded them in by hand and haven't had a problem since - I did loctitie them, but thought that I'd end up backing them out again if I used the double nut method to re-insert them.  I torqued them to spec and that was it.
|  04-18-2006, 06:19 AM |
| Registered |
			i look at the ones that come out as a bonus.  i install new ones with loctite....cheap, and easy.
				__________________ poof! gone | ||
|  04-18-2006, 06:26 AM |
| Registered | Quote:
				__________________ 2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab | ||
|  04-18-2006, 06:44 AM |
