juicersr's Avatar
Valve cover studs
Just adjusted my valves this weekend and seems like more valve cover studs than last time unscrewed when i took the cover nut off.(Last valve adjustment, seems like only 2 or 3 studs came out and this time it was 4 on one side and 3 on another.) I used a vice grip to get the nuts off the studs (some of which were rusted on the studs), and simply screwed them back in to finish the job. Thinking now, should i have used loctite or something to keep them from backing out? Anyone else have this problem?
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 01-30-2006, 05:27 AM
I never had one come loose, you should have loctited them back in.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-30-2006, 06:20 AM
jimi_c's Avatar
I had 12 come out the first time I did mine - I cleaned them well and used loctite when I put them back in. Generally, I found that it was almost impossible to use vice grips to take the nuts off without buggering up the stud- I actually had to replace a few studs when I tried that method first. I ended up putting two bolts on the other end, tightened the bolts by hand as hard as I could, put the double nuts in the vice and used a socket to pull off the stuck one on the other end - worked like a charm and didn't leave any scarring.
Cory H
85 Carrera
Old 01-30-2006, 06:45 AM
randyrap's Avatar
I had the same problem today. One question I have is how do I put the studs back in? Can they be threaded back in by hand and rely on loctite to hold them in place?
Thanks in advance ........... Randy
83 911 SC Coupe ''Sunroof Delete''
Are we having fun yet ?
Old 04-17-2006, 07:06 PM
Now in 993 land ...
aigel's Avatar
Randy:
Put two nuts on there and fasten them against one another. Then use a wrench to screw the studs back in. Yes, use red loctite to reinstall.
George
81 SC (sold)
Old 04-17-2006, 07:42 PM
jimi_c's Avatar
I threaded them in by hand and haven't had a problem since - I did loctitie them, but thought that I'd end up backing them out again if I used the double nut method to re-insert them. I torqued them to spec and that was it.
Cory H
85 Carrera
Old 04-18-2006, 07:19 AM
vash's Avatar
i look at the ones that come out as a bonus. i install new ones with loctite....cheap, and easy.
poof! gone
Old 04-18-2006, 07:26 AM
Scott R's Avatar
Same here, I have a bag of new studs from a local metric supply store, I think I paid like $20 for 50 or so.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-18-2006, 07:44 AM
