Front hub removal
How does one go about removing the front caliper and hub (to get the strut powdercoated)? I have removed the nuts and bolts, but I assume the grease cap needs to come off, too? Do I just pry it off with a screwdriver?
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please ![]() Chad aka "Chili" 1974 Base coupe in Carrera outfit. No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.) My car http://www.pelicanparts.com/gallery/CHILI 1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras. |
If all you want to do is get the assembly (rotor and all) off the strut, knock the cap off (cold chisel and hammer or large channel locks) and remove the wheel bearing retaining nut and then grab the rotor and pull!! That is it. Once the retaining nut is off the outer bearing will fall out and then it is smooth sailing, once the outer bearing tumbles to the ground the whole assemble will likely follow suit.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Ok, thanks Jeff. I figured that, but I'm wise enough now to know it's better to ask than to start beating or prying on stuff without having a clue. LOL
Bill 997.2 |
cycling has-been
Porsche manual shows correct way is to lay one big a$$ screwdriver across the high points of the hub, then, with big a$$ screwdriver #2, lever cap off evenly around the hub
reinstall with a block of wood & hammer, never metal to metal hammer. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Hey, that link is interesting.
