dweymer's Avatar
915 Trans rebuild-internal diagnosis
Here it is:
Donnie
Currently Porsche-less.....
Old 04-09-2006, 03:53 PM
dweymer's Avatar
Donnie
Old 04-09-2006, 03:54 PM
dweymer's Avatar
So what do the experts see?
I think:
Reverse is chipped(how???)
#1 syncro can be flipped
#1-#2 slider can be filed
#2 syncro needs replaced.
The lint is from my initial cleaning rags.
Donnie
Old 04-09-2006, 03:56 PM
take a bunch of pics of each issue, from different distances and lighting, then pull them up on you computer and pick out the ones in focus and try again. try no flash in outside light.
206 637 4071
Old 04-09-2006, 05:24 PM
dweymer's Avatar
John, I will try that tommorow, do you see any problems with anything shown? Also are the markings on the brake bands normal(not scratches, smooth)?
Donnie
Old 04-09-2006, 05:33 PM
the 3/4 sleeve is chewed, and a couple of pressed on syncro teeth look kind of blunted. hard to see the rest. polished surfaces or areas of missing friction surface denote worn syncros. you should replace them all anyway, as well as the 1/2 shift sleeve and both 1st and 2nd pressed on teeth among other things.
206 637 4071
Old 04-09-2006, 06:09 PM
dweymer's Avatar
ahh, that sweet sound of money....falling out of my pockets
Donnie
Old 04-09-2006, 07:02 PM
dweymer's Avatar
Chipped reverse:
1-2 slider:
1st gear dogs
2nd gear dogs
Donnie
Old 04-10-2006, 03:17 PM
the slider is chewed, and 2nd dog teeth look worn. but you should replace 1st and 2nd teeth anyway because they are old and they both tend to shed teeth. safer to start new. you have the old style symetrical teeth on 1st, and the matching slider. i would suggest updating to the assymetrical teeth and slider, and new style brake bands, dogs and anchors in both 1st and 2nd. they shift better. the reverse gear will probably be ok with the small chip. they don't get a lot of stress.
206 637 4071
Old 04-10-2006, 05:58 PM
dweymer's Avatar
John,
Could you post some pics of new sliders,dogs, etc? I could not find any, and it would be a good resource for others that come along.
Thanks,
D
Donnie
Old 04-11-2006, 08:57 AM
Irrationally exuberant
ChrisBennet's Avatar
Upgrading to the newer style 1st (asymetric) requires the newer "guide sleeve" as well. That's the 3 pronged thingy that mounts on the shaft that the slider or shift sleeve slides on. I call it the "Klingon Throwing Star" but that term is not in general use.
A couple of years ago I had to pull apart a transmission I'd updated to replace the guide sleeve because I hadn't realized the width of the guide sleeve (and corresponding slot in the shift sleeve/"slider") was different. Very embarrasing.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-11-2006, 10:07 AM
Elombard's Avatar
Hey guys how do you feel about bearings, automatic replace at 100K? talk about money adds $1k to the rebuild. Your thoughts?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 04-11-2006, 12:29 PM
Are these helpful/clear enough? New 915 1st gear asymmetrical synchro hub (dogteeth). I also have the 1/2 slider, spider, synchro rings and brake bands.
Old 04-11-2006, 07:44 PM
dweymer's Avatar
yep, thanks. Pics of the slider would be good for reference too.
Donnie
Old 04-11-2006, 07:46 PM
RETIRED
Joe Bob's Avatar
Ahem...where do ya get new stuff that you don't have to bend over for????
2012 ML350 3.0 Turbo Diesel
Old 04-11-2006, 07:53 PM
New 915 1st/2nd operating sleeve (slider)
Old 04-11-2006, 08:32 PM
Jim Williams's Avatar
Jim,
Thanks for the photos, now I understand what the asymmetricity refers to.
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 04-11-2006, 08:39 PM
One more of the 915 1-2 slider showing 2nd gear symmetrical side closeup:
Old 04-11-2006, 08:43 PM
New 915 1/2 guide sleeve (spider):
Old 04-11-2006, 09:01 PM
Originally posted by john walker's workshop
... i would suggest updating to the assymetrical teeth and slider, and new style brake bands, dogs and anchors in both 1st and 2nd. they shift better.
Good info in this thread!
I will want to update to the assymmetrical style as well.
Is the above mentioned parts the complete list for this?
If so, could you please give the corresponding part numbers for the update or are they all already mentioned in the pictures above?
Thanks in advance,
Walter
Old 04-14-2006, 01:51 PM
