-   -   Calling all audio gurus! (http://forums.pelicanparts.com/porsche-911-technical-forum/278439-calling-all-audio-gurus.html)
WydRyd 04-20-2006 11:20 PM
I'm looking at upgrading the sound system in my cab and am thinking of the following:-
- New Pioneer CD Tuner with MP3 & iPod capability + 12 Stacker
- Front 6.5" Component Speakers (thinking perhaps Pioneer TS-C160R's)
- Infinity Basslink Powered 10" Subwoofer in trunk
- Two channel JL-Audio Amp (~70w RMS per channel @ 14.5v)
Possible configuration:
- The Tuner will feed the Basslink directly via the subby output.
- The Amp will drive the two door speakers.
- The CD Tuner will drive the rear 4" speakers.
Does this look like a good combination to you guys?
Not really after audiophile quality sound because I'm on a budget and, well, it's a Cabriolet ;)
I've read on these forums that a good pair of 6.5" speakers & amp will suffice and no subby is really required, but I just want that little extra bass :rolleyes:
Advice/suggestions?
jbrinkley 04-21-2006 04:54 AM
I did sort of what you got there, JL 300/4 6.5 diamond audio in the doors, and one self powered kenwood sub thing.
in the end it ended up like this
JL amp bridged to front components
powered sub from deck
ditched the rear stuff all together. It sounds better without. Don't know why.
also moved tweeters to kick panel.
I love that kenwood sub box, But I couldn't fit it in the smugglers box so it's behind pass seat.
Ptoscano 04-21-2006 05:20 AM
subsolutions.com, bass is amazing even with the top off at 70mph. Bass blows through duct work
Super_Dave_D 04-21-2006 07:03 AM
I disagree with the "no rear". You need the rear speakers for the actual stereo concept. I have Infiniti 4x6's in the back and infiniti 6 1/2 in the doors and when I fade to just the front there is a major reduction in stereo and sound quality. Just my opinion. In addition, what I have, even though they are high speakers and amp, is still lacking the bass punch I would like.
Christien 04-21-2006 07:18 AM
Perhaps a dumb question (especially from someone who's supposed to know audio gear) but while we're discussing gear, will the amp have an impact on sound quality vs. whatever amp is built-in to the stereo deck itself? There's no amp in my car, and I'm looking at putting in a small sub to help fill out the frequency range. Will an amp produce better sound quality or just more volume? I don't need massive volume - it goes loud enough as it is, but I would like better sound quality.
Sorry for the (kind-of) hijack!
Chris
techweenie 04-21-2006 07:20 AM
With an open car, I'd look for 100-125 (real RMS) watts per channel. You can get by with less in a closed car.
mschuep 04-21-2006 07:31 AM
FWIW
I might change those 6.5's in the front to 3 ways with a decent tweeter on it. With the sub and those component speakers, you would get a lot of low-to-mid up front, but your only high freq would be coming from the rear. Additionally, I might get some 6.5's that don't require as much power, then you could ditch the amp and use the head unit for all 4 speakers.
edit: or you could just add some tweeters
JonT 04-21-2006 08:01 AM
has anyone tried quality 8" speakers in the doors? What about a fiberglass enclosure shaped the same as the door pocket? This would be ideal.
dbox 04-21-2006 09:35 AM
I'd like to upgrade mine as well but I hate the look of the new school cd players. The blaupunkt in mine definitely fits the look of the vehicle. Do any manufactures make new stereos that don't look outrageous?
Leidenschaft 04-21-2006 10:04 AM
For the original poster,
I'd like to add that you normally want to keep all your audio gear of the same brand (speakers, amps, deck, subs). When you do that they give you the best sound reproduction because they are all engineered and tested to work within that particular brand. If you don't have the option of sticking within all the same brand, then try to stick with same brand of deck and amp.
As far as the amp question asked earlier, it improves volume and SQ (sound quality).
randywebb 04-21-2006 10:54 AM
Yes - the amp needs adequate power to drive the speakers -- without 'straining' and it needs to be of decent quality overall. There are many choices...
The rear speakers are helpful in getting a sound stage -- it will not be the most accurate sound stage, but you are never going to get real audiophile sound in a 911 for several different reasons.
Dottore 04-21-2006 11:04 AM
Nakamichi make several very nice simple and elegant black units - without all the chrome and lights other manufacturers seem to find fashionable.
jac1976 04-21-2006 11:25 AM
Christien-
I am not an "audio guru," but anecdotally I would recommend an amp. I do not know of any head units that can provide a clean 50 watts per channel and you want enough power to move your speakers, especially if they are high-end. I think of it like this: even at low volumes you can tell the difference between a low-power and high-power system. Without the juice to move a larger magnet, you get distortion. This does not mean you have to spend big bucks, but you want to do your speakers justice.
Christien 04-21-2006 11:28 AM
Thanks, that explains it just perfectly - exactly what I needed to know. Much appreciated!
randywebb 04-21-2006 12:40 PM
Nakamichi = high quality (same for Alpine)
During the time of the founder, Etsuru (sp?) Nakamichi, it was very much like Porsche; originally called Nakamichi Research, they went for the very highest performance (with some maintenance required). Today it is still a high quality co., tho the products aren't at cult status any more...
jac1976 04-21-2006 12:55 PM
Eclipse (Fujitisu Ten) if we are going to recommend brands. Better than Alpine, but unfortunately have become rather garish in appearance since their introduction about 15 years ago. With an early car, I'd put the head unit in the glove box (cubby box) anyway and have the stock in the dash as a dummy.
Ron.G 04-21-2006 01:02 PM
Rockford Fosgate makes a great amp and are not super expensive. real world specs not some hyped up numbers.
You want a amp that has low THD. In laymens terms you want a amp the has very low distortion and signal to noise ratio.
A cheap amp will add un wanted distortion as volume increases. it will also help to destroy your speakers.
Signal to noise is bascally "self noise" that I'm sure you have heard before. turn on your system and hear that wonderful hiss.
randywebb 04-21-2006 01:27 PM
all good - we can add a/d/s
today, massive neg. feedback allows very low THD - distortion - numbers - this can cost in other ways tho
Find a few good brands near you and listen carefully w/same speakers... I don't think you can figure things out with specs. anymore...
WydRyd 04-21-2006 11:07 PM
Hmmm, I like crystal clear sound and good bass response. I'm told the Focal PolyKevlar 165K2P speakers are absolutely awesome, but I dont think I can afford the hefty $799 price tag :confused:
The Focal's with an Audison LRx 2.250 2-channel amp would be a perfect combination, but once again, $$$$!!!
Just dreaming here :(
Redlineshftr 04-21-2006 11:21 PM
WydRyd,
If you could afford the focals you would be blown away. They wouldn't sound like 800 dollar speakers powered off your deck but with the right amp they would sound incredible. IF I were you on a budget I would get an eclipse deck, a GOOD 4-channel amp, and some decent 6 1/2 door speakers. Clean sounding bass is very hard to get out of a porsche without cutting and doing all kinds of fiberglass work... all of which is very expensive. Im sure Hotshottt (one of my good friends that works at a highly respected audio shop in town) will chime in on this thread with some good info and ideas for you later tonight.
Mike
