Does anyone actually prefer the 915 over a G50?
I can't remember the name of the book, but I was at Barnes and Noble the other day, and one author wrote "...the 911, with the G50, shifts like a Camaro".
regards, Hans 83 SC |
I absolutely prefer a properly working 915.
64 356C Cabriolet 85 Carrera Coupe...Walker-maintained...Wong-chipped 02 Yukon XL 2500 82 Vespa P200E 186,000 MPS.....not just a good idea....its the Law! "Too much of everything is just enough" |
I don't know about prefer, but most 911s have the 915 and they get rebuilt more than upgraded to the G50. It doesn't shift as smoothly as a Honda gearbox, but does fine if you can shift and clutch deliberately. I've never shifted a G50 so I can't compare.
Joe 85 Carrera 64 Honda Dream - for sale 71 Hodaka Super Rat - keeper |
Formerly bb80sc
I prefer the 915, more viceral, raw feel. The G50 feels too disconnected to me. Then again, my 915 is pretty well dialed in...
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
I do.
The G50 is heavier, makes annoying rattles and eats up more hp. Edith: ... and a repair or a new clutch is nearly double the price. Last edited by carrera84; 04-09-2006 at 02:15 AM.. |
With my cars, the 915 seems to shift more smoothly when it's cold, and gets worse after warming up. The G50 is very balky when cold, but gets much smoother after warming up.
I know that sounds strange, but that's the way it is with mine. Neither is new, so it may be due to wear vagaries. Since most driving is done after warming up, the G50 would seem to get the nod for me. Another factor to consider is the clutch 'feel'. All 915's have the cable clutch, and all G50's have the hydraulic clutch. The cable clutch has a longer throw, but more feel. The hydraulic throw is much shorter, but it's more difficult to really feel the exact point of engagement, and smoothness can suffer as a result. The effort is also a little higher with the hydraulic clutch since the throw is shorter. The G50 does rattle. It annoyed me to begin with, but you get used to it quick. HTH, ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
I love the 915. It's raw and untamed. It's a hoot. Of course, it takes practice.
"Igneous Aquam et Laudi semper" Carl Muckley |
I have a G50 in my race car and I prefer it because it can handle the abuse and HP better but the main reason is that it shifts faster than a 915 and lowers track times. It heavier and I am to happy about that. I supose a tricked out 915 with a Wevo dog gear setup and all the other trick parts from them may be the way to go and I have been looking into it for my race car.
1978 race car scca GT2 1998 C2S sold 1996 C4S sold 1973 911 T restored with 2.7 RS running gear 1970 911 E Project |
I love my mag case 1977 915 with LSD. It works great and its very light and easy to work on compared to a G-50. I run my car on the street and it handles my 370 HP 3.5 RSR engine's 269ft lbs of torque fine. I have run my engine up to 9200rpm many times and its held up fine. I have always used a stock early 1970's all aluminum pressure plate I found used for cheap. Its been in there for 15 years and I've never needed a new clutch disc and I drive my car hard. The setup has about 40,000 miles on it now.
Paul Weir |
Yes, definitely...everyone that does not have a G50 prefers the 915.
Mike |
Once you've learned and gotten used to a properly working 915 transmission, it's a nice thing. The main issue I had with the G50 (when I finally got one) was that the clutch replacement cost was higher.
I dunno, I always figured it's good that the 915 has all these 'negatives' against it because I could walk up to a seller with a 1986 Porsche 911 and say "Oh no, this has the old transmission! You gotta give me a discount!".
2014 Porsche Cayman S 2001 BMW 525i Touring 1996 Porsche 911 (Gone to Germany) '86 911 Carrera (Gone to Aruba) |
Metal Guru
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
how about the 901? definitely not like a honda, but raw. That's all I've driven so far. How does that compare to the 915?
Amir 1970 911T 1967 912 |
I agree.
The only reason I would consider a G50 in a 915 car is for a serious HP 500HP+ The 915 in my 73S really, really surprised me. Once I got used to it, the only slow shift is 1st to 2nd ( just because 1st is geard really low) once in 2nd man it shifts fast. It preety much comes down to how fast I can move the stick. And this is a stock gearbox, I cant imagine a WEVO box. Also love the feel when shifting gears and clutch I even liked the cable clutch in a old VW rabbit I unfortunately had to drive. |
I second that . I think the title for smooth shifting, indestructible, manual transmissions goes to BMW. I am biased thought. |
I've got both, stock they both were nothing to rave about,
The 915 absolutly needs zero clearance bushes, zero slop coupler, sharp syncros, and a factory short shifter. The same sort of thing is needed on a G50 only its a lot more expensive to get it done, RS shift linkage, RS shift rod, steel syncros, lt wt flywheel, hard trans and engine mounts.
ianc said, "With my cars, the 915 seems to shift more smoothly when it's cold, and gets worse after warming up. The G50 is very balky when cold, but gets much smoother after warming up."
Mine 915 is the same way. Is that a sign that the synchros need a freshening up?
Big Hooters and 911's will always be in style |
915 Trans
I would say the only negative thing is the warm up. Once the tranny oil warms a bit my 915 shifts like a dream. Its all about learning your particular car and allot of patience.
Banned
I absolutely second Momo's opinion., Antonio.
