violent shuddering on take off
Hi,
When i move off in 1st gear, sometimes i get a VERy violent shuddering, where the whole car is shaking and the gear lever is shaking. It doesn't happen always, but atleast once each time i drive the car, sometimes more. I.e, when moving off, you engage the clutch just enough to get the car rolling, and when the engine revs match the wheels, you can let go of the clutch pedal completely. The shuddering happens when the revs are almost matched. It also has a much greater tendency to happen when the car is on a steep incline. Thanks Alot!, Adam
_____________________ '73 RSR Interpretation ---------------------------------- Last edited by StayGold808; 04-22-2006 at 12:23 AM.. |
I get this as well. Old clutch - well at least in my case.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Your clutch could be contaminated with oil, creating a situation where it grips/doesn't grip very quickly.
Another possibility is a broken motor or trans mount on the left side. Check all 4 mounts to be sure.
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
Bet on transmission mounting nuts loose.
POKDUB Porsche 911E |
Have you changed your clutch cable recently by any chance? Mine did the same thing. Adjusted the cable and everything was fine.
Mike
Mike |
I have had the same on mine exactly as you describe. In my case it was some oil on the clutch plate (leaky seal) plus having a VERY steep curved drive into my garage = need to slip clutch = burnt clutch.
If you had an old sedan, you'd swear it was axle tramp!! Even had it on my WRX - one day I'll learn to use a clutch properly. Tim
Swapped my WRX Sti MY02 for a Porsche 911SC '83 Keep buying parts to make it look older. Mid life crisis is now in its 12th year. |
GFCC
Adam, You need to adjust your bowden tube and then adjust your clutch cable.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
10 minutes, problem solved. two 15 mm wrenches. Doug
1971 RSR - interpretation |
I suspect it is the mount that is pulled apart rather than compressed?
Scott 1982 911 SC 1962 sunroof bug 1991 WE Vanagon CARAT WRX conversion |
If one of the mounting bolts is lost, the engine and trans will drop a little on that side. Due to the rotation of the engine, the engine and trans twist counterclockwise under load. If a right side bolt is missing the load has the effect of "fixing" the problem by pulling the engine up to the mount. The clutch engagement seems a little slow, but once that mount moves up it feels normal. The left side under load will continue to pull away from the mount, then spring back producing the juddering. Just a funny thing I've noticed on 3 different cars. Certainly all the mounts should be looked at.
I did suspect it could be oil on the clutch plate....
i didn't replace my clutch cable, but i did have to disconnect it then re adjust it after fixing my pedal assembly... Ok, i did some reading on what the bowden tube is, but could somebody tell me how to adjust it? I'm not sure if i'm thinking of the right part. Thanks for the help everyone
_____________________ '73 RSR Interpretation ---------------------------------- Last edited by StayGold808; 04-22-2006 at 12:39 AM.. |
Loose/slack clutch cable.
You need to force curve into cable by loading it against the firewall Mine arches above and away from the throttle bellcrank. It is adjusted with the 15mm nuts where the clutch cable attaches to the tranmission.
I had this EXACT same problem a while back... even posted a question on the PCA website. I replaced 22 yr old motor/trans mounts and re-adjusted the clutch cable. Problem solved!
Good luck with it.
G-Body 3.6 Transplant |
thanks alot to every1 who helped. I adjusted the bowden tube a bit, and problem solved.
As a by-product, the clutch engages over a much shorter distance, and hence the meeting point is much higher now. How high is it supposed to be? Because i used to have mine much lower, but my brother has a boxster, and his clutch engages about the same as my 911 after the adjustment. Thanks alot!
_____________________ '73 RSR Interpretation ---------------------------------- |
