mark '87 930's Avatar
little things about the 930...
A few questions about my '87 930...does anyone know
1) The automatic heater control in between the seats, is it supposed to illuminate when you turn your lights on? In the PET, it shows a light bulb in there, but I couldn't find one, or a socket for one..
2) My rear window wiper, when I shut it off, it stops when I turn the switch off, it doesn't go back to the parked position. Would that be my wiper motor that needs to be replaced?
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 03-25-2006, 04:34 AM
BlkBird's Avatar
Yes, there is a light bulb in there. If you remove the seat and the access panel on the sides (there are two - pick the side you prefer) will be readily accessible. There is a tiny bulb and socket - the bulb looks like it melted into a blob - never seen one like that before - that you can replace.
Have to say I didn't bother with mine when it burnt out.
C.H.
Boost Addiction - honestly, I have it under control
1989 911 Turbo Cabriolet
Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace
Old 03-25-2006, 04:40 PM
BlkBird,
1956 Chevy 3100
Old 03-25-2006, 04:47 PM
BLlkBrd,
You wouldn't happen to have a picture of it would you? Where is it exactly? at the top?
1956 Chevy 3100
RPKESQ's Avatar
The rear wiper is not self parking.
Who Dares, Wins!
Old 03-25-2006, 06:39 PM
Actually, the rear wiper is supposed to self-park. All of mine do.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 03-26-2006, 05:50 AM
BlkBird's Avatar
Yes, it plugs into the top. It's right under the rotary knob but I'm afraid I didn't take a photo. I was trying to track down the handbrake wire (brown/white) and only noted the bulb because of it's odd shape.
One of those "Gee I'll replace that one day" observations.
BTW. What part of TO are you in? I lived in Mysterysaga for a number of years before relocating to Atlanta.
C.H.
Old 03-26-2006, 08:12 AM
I'm in the beaches now. When I moved here from Montreal in 97, I moved into Missiassauga until 2004, then I wanted to live in the beach. Nice down here, I'm a sporty type, so the beach is perfect for me!
1956 Chevy 3100
Old 03-26-2006, 02:47 PM
RPKESQ's Avatar
My rear wiper never self parked from new. I thought they all were that way.
Who Dares, Wins!
Old 03-26-2006, 08:40 PM
Nope.
JR
Old 03-27-2006, 03:55 AM
If it is supposed to self park, then maybe it's a conneciton? of maybe the motor?
1956 Chevy 3100
Old 03-27-2006, 06:23 AM
Mark,
I've never had to fix one, so I'd suggest you take off the motor assembly and disaasemble it from the wiper arm, if there are no bad connections visible where the wires plug in. There will be some contact rings where the wiper arm makes and breaks circuits when the arm revolves and there is probably something wrong there. Perhaps they are dirty, or the arm doesn't make good contact with them for some reason.
JR
Old 03-27-2006, 06:36 AM
Thanks, I'll check that out.
1956 Chevy 3100
Old 03-27-2006, 06:52 AM
The assembly is certainly interesting to say the least... I had a similar problem with my heater switch in-between my seats. Basically, as the motor rotates, the contacts are supposed to be all touching each other. As they rotate through the 'park position', the third contact which is connector 53a (hot at all times).
In essence, as the motor rotates through it's sequence, it is always 'hot' until in the park position. With your switch on, it provides power to the motor at all times.. when you turn it off, depending on where the motor is, the current keeps going to it from the live wire..
I'm horrible at explaining these things, but take hopefully these pictures I high-jacked from another thread will work.
Thanks for your advice though..I finally got around to looking at this. I think that everythign works on my car now as it should...
1956 Chevy 3100
Old 04-23-2006, 12:12 PM
Here's another pic. of the motor assembly and the contacts.
1956 Chevy 3100
Old 04-23-2006, 12:15 PM
Banned
diabolos88's Avatar
I think the wiper self parking issue relies on a relay in the rear engine on the left side. Mine didnt park and then I switched it out now works fine.
Mark 87 930
What bulb is the one you are talking about? The center climate control console? take a pic of what you are talking about.
Old 04-23-2006, 02:37 PM
the fuse is actually, as is the relay one of the sources for power to the motor. If the contacts are not touching, it will not self park.
As for the light, here is a shot (I took it from this board) of the automatic heater in-between the seats. According to the manual, it looks like it should be illuminated, and others have said that there is a light in there...
1956 Chevy 3100
Old 04-23-2006, 03:12 PM
There is a light bulb in there. The part number is 900.631.132.90. It's a whopping 1.2 watts.
JR
Old 04-23-2006, 07:45 PM
