K9Torro's Avatar
Red Tops at Costco
Hey -
Was stumbling through the local Costco on Sunday and low and behold they had Optima's new on the shelf,
the red top was $104
the yellow was $145
My parts store wanted $135 for the red top,
Todd
Old 04-24-2006, 04:48 PM
Administrator
Jack Olsen's Avatar
If you're interested in lighter and cheaper, see my recent thread on the $43 sealed lead acid battery (it's only 19 pounds).
Old 04-24-2006, 09:15 PM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Costco is where I purchased my last Optima - was $99 ~ a year ago. Best deal I've found!
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 04-25-2006, 04:39 AM
msk1986911's Avatar
Does the red Optima provide enough cranking power to turn a 3.2L? The battery currently consuming the trunk is an Interstate behemoth, weiging about 50lbs, rated at 850 CCA.
Old 04-25-2006, 09:25 AM
Don Plumley's Avatar
Red Top Optima is fine for your 3.2.
I'm an Odessey Fan myself...
Don Plumley
M235i
Old 04-25-2006, 09:36 AM
JTL JTL is offline
JTL's Avatar
Thumbs up Odyssey
I decided to order an Odyssey after reading a recent post. It is about 1/2-size of the Optima and lighter in weight, ~25lbs. Now I just have to figure out how to secure it in the car.
If you decide to get an Odyssey don't forget to order the automotive post kit.
jt
-84 targa
Old 04-25-2006, 10:01 AM
i have a red top in my 91 silverado, its running my truck and my 2000w rms stereo with not a problem. great battery
Old 04-25-2006, 10:28 AM
Eric86Red911's Avatar
I'm pretty sure I read on Rennlist that if you have any problems, Costco won't honor the RedTop warranty, but will send you somewhere else. Since their price was the exact same as Pep Boys here in Chicago, I bought mine from Pep Boys for like $115.
1995 993 C2, speed yellow. Protomotive Stage 1 twin turbo. JRZs, RS parts, DL1 logger, etc.
Old 04-25-2006, 12:38 PM
Re: Odyssey
The post kit is the -T option.
For a hold down, you can get one at Rennline, West Coast Batteries (Odessey distributor) or do it yourself.
Don Plumley
M235i
Old 04-25-2006, 01:20 PM
"I'm pretty sure I read on Rennlist that if you have any problems, Costco won't honor the RedTop warranty, but will send you somewhere else."
My Costco store merely replaced mine with one off the shelf. No questions asked. However, this was done during the free replacement period.
Sherwood
Old 04-25-2006, 06:16 PM
scottb's Avatar
Let me first say that I'm not concerned about my car's weight -- it's just a weekend driver.
A couple of weekends ago, however, it wasn't driving anywhere. The battery was dead, and wouldn't take a charge. So, speaking of Costco, I went to my local store and simply bought a direct replacement Kirkland (Costco brand) battery. It has a 100 month warranty, with the first 36 months being full replacement. I think I paid $56, which is an incredible value for a battery with that warranty. And, it had a higher cold cranking rating than the Interstate battery it replaced!
So, for those out there reading this that simply need a direct replacement battery, and don't care about brand name or weight savings, the Costco battery sure seems like a great value.
My $.02. (Sorry to semi-hijack the thread.)
1984 Targa
Old 04-25-2006, 10:02 PM
Lot's of good replacement batteries out there. The difference is that only a few reduce the chance of battery acid spreading around the sheet metal.
Sherwood
Old 04-25-2006, 10:41 PM
scottb's Avatar
Sherwood: You raise an interesting point. I've owned maybe seven cars in my lifetime (and a helicopter with a lead acid battery). Not once have I had a problem with acid leaking, yet I read here on the board time-and-time-again about people doing repairs as the result of leaking batteries.
Aside from physical damage or a defective case, what causes supposedly sealed lead acid batteries to leak acid? Is it due to alternator and/or regulator problems? Something else?
1984 Targa
Old 04-25-2006, 10:47 PM
Scott,
Most lead-acid storage batteries are not sealed. The individual cells vent to the atmosphere through the vent caps or other venting passage. When the battery is charging, heat is generated and the electrolyte (water and sulfuric acid) gets warm. Overcharging exacerbates this. If the vented gases aren't directed to the outside, they linger and settle around the battery. If the fluid level is too high, the heated electrolyte expands and overflows out of the vent caps.
If your vehicles haven't experienced any telltale signs of acid leakage (not even on the battery posts?), consider yourself fortunate. On our 911s, the battery (or batteries) are housed in a semi-enclosed area. If not inspected regularly, a little acid and some time can go a long way toward a lighter chassis.
Sherwood
Old 04-26-2006, 12:16 AM
Even normal "venting"..if not exactly leaking...can cause local corrosion of the VERY nearby electrical fuse box and components.
If you go "normal" battery...get the one with a vent nipple and attach tygon / clear vinyl tubing to that and ROUTE TO THE OUTSIDE !!!
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-26-2006, 06:56 AM
