Jbabic's Avatar
WUR Adjustable
Anyone out there that can make my WUR adjustable. I see the instructions/prints, but I just don't quit get it...thought maybe someone would be in business to do this mod.
Old 09-09-2003, 05:41 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Not a bad idea, i wonder if that's possible?
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 09-09-2003, 07:38 AM
Somewhere in the Midwest
MotoSook's Avatar
I've been itching to modify my and fully document it. I've not a little used drill press int he garage, that I'll put into action...wait a couple of weeks maybe?
Since I am now running with an 81+ WUR in my 78 engine, I've got a little more motivation to get my stock WUR reconditioned, modified and back in my car.
Old 09-09-2003, 07:45 AM
Jbabic's Avatar
just let me know if your willing to do mine....thanks.
Old 09-16-2003, 04:30 PM
Souk -
Every get aroudn to modifying your WUR? Curious as I need mine done and I am in the area.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 04-24-2006, 12:59 PM
Crotchety Old Bastard
RarlyL8's Avatar
A buddy of mine just did his WUR, check out this thread:
Modified my WUR
Old 04-24-2006, 02:22 PM
oneblueyedog's Avatar
I did it. It surely was adjustable for cold pressure. It's just that my heating element was shot and it always ran poorly in the warm up phase until I got a wur from Pelican (superceded from original PN). I think the engine eventually warmed up the bimetallic heating element after about 8 min.
I think you break the heating element when you "whack on the plunger". The green insulation paint was cracked and chipped when I took the old one apart.
If there are aftermarket heating elements then I would have a spare.
If I had to go back in time- Buy a new one!
78SC coupe, Silver Metallic
Old 04-24-2006, 02:56 PM
loot87's Avatar
This guy posted on the Rennlist 930 board a couple of weeks ago. He says it runs $300 to clean it up and make it adjustable:
Hello,
I offer the service of making your 930 WUR fully adjustable. I rebuild the unit and modify it, adding adjustment features for the cold, warm, and full-throttle enrichment control pressures. I also provide a means of adjusting the full-throttle enrichment threshold (the point at which the WUR enriches based upon manifold pressure). All of the adjustment hardware used is high quality stainless steel for longevity without rust or corrosion. Before shipping it back to you, I can set your WUR to exact factory specs or whatever settings you desire. If you provide me your engine details, I can offer my suggestions for custom control pressure settings and set the unit accordingly. A 12 page color instruction sheet is included with each unit that details each adjustment feature and documents your particular WUR settings.
Please contact me for more information.
Brian Leask
bleask@cox.net
Chris Cope
91 911 Turbo
Lyons, Colorado
Old 04-24-2006, 03:37 PM
