The Porsche Gods are not smiling favorably on my 3.5 twin plug motor. Here's the problem: On cold or warm start the engine will start, try to idle, start to stumble and then stall. This came on rather suddenly at the end of my 4th autocross run this weekend (was running OK before). When moving the car runs fine, but when I stop I have to pull up the hand throttle to keep the engine from stalling.
When I first started the engine about 3 weeks ago I had some problems that were diagnosed by a local shop as a bad WUR (rough cold start with no idle then high idle when warm). I replaced it with a rebuilt unit, had the mixture set by the shop (1.5 CO, 24 deg advance, 950 idle), and all was well. The mixture was deliberately set rich for safety reasons (crappy CA gas). I've searched the board archives and haven't really found anything conclusive. Any ideas from those far wiser than me? -Jon Engine stats (if it's helpful): SC engine (78-79) base 100 mm P/Cs 3.3 crank Twin Bosch 6-pin CDI boxes w/Andial harness Stock coils 964 distributor converted for mech advance 78-79 CIS |
RETIRED
Hunting or surging is usually an intake leak.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
What's the condition of the air box? Perhaps you should check the seams. Does running rich produce any backfiring?
RETIRED
The LIGHT spraying of carb cleaner or ether/quick start in the suspect areas will pinpoint a leak....obviously you will need someone to keep the revs up so that it won't die on ya.
The airbox is new, but I won't rule out a leak. Thanks for the ideas. Any others care to chime in on my issue?
Make sure the pop valve is properly seated. Including the epoxy used to hold it in place. However a vacuum leak causing your symtoms would have clearly shown evident on the exhaust analzer so maybe you could have it rechecked once you check for obvious air leaks. Make sure the throttle body/sensor plate boot is secure as well.
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
