What do you think of my custom strut tower braces?
Just made these today, I think they turned out pretty nice...
closer pic
last one
Looks good! but why 2?
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
I dunno, why not? Extra strength...
Maybe you could really open up the rear one and tighten up the front one and get some more toe in. :>)
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
What?
Looks like they should work as good as the store bought ones. What are they made out of? How much do they weigh? One may be sufficient to do the job and if so the second one is only adding weight.
Tom J. 911SC Cab SCWDP CaymanS |
Do you have a better shot of how you connected the ends to the towers?
83SC black on black 01 Chevy S10 08 Buick Enclave |
They are made from 3/4" thick 6160 solid aluminum rod with 10mm heim joints on each end. On side is right hand thread and the other is left hand thread so that it can be adjusted without removing the end. It is just attached with a longer bolt through the heim joint. Not sure what the weigh but not much a few pounds maybe.
Wer bremst verliert
I respect the DIY approach.
I think you might gain some stability/rigidity if you could drop tehe passenger side of the forward one to the brake master cylinder mounting bolts or triangulate to another ridid point.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
I think your DIY approach is as good as any commercial strut-to-strut setup. However, you might have the same rigidity using a single bar, but with a more difficult-to-fabricate mounting bracket on each strut tower.
MHO, Sherwood http://members.rennlist.org/911pcars |
I guess you must be a machinst, to do the cross thread
![]() nice work.
Fat butt 911, 1987 |
