Counterclockwise?
How do you attach side molding?
I had to pull back the side molding so that I could pull out my torsion bars.
How does it go back on?
I looks like I need to pull it off completely and slide it on from the back.
PITA
Rod
1986 Carrera
2001 996TT
Old 04-25-2006, 12:33 PM
911S Targa's Avatar
Very easy. Take some dish soap, rub it on the rubber, and it will slide right back on.
Bill
MID9 #4
if i cant play with it ,,i dont want to own it
Old 04-25-2006, 01:00 PM
Counterclockwise?
So I need to pull it off completely.
Wash and soap it down and slide on fom the back?
Rod
1986 Carrera
2001 996TT
Old 04-25-2006, 01:02 PM
911S Targa's Avatar
Well, for me, I already had them off, when I took my rockers off to clean off the 20 years of grime, and remove my AC lines. I had the same problem. I would get them in about 12 inches, then they wouldnt budge. I took straight dishsoap (no water added) and placed a good layer on the parts that met the rocker lips.
Bill
MID9 #4
Old 04-25-2006, 01:27 PM
The procedure is described in the factory manual.
Install one end, then work towards the other end. Fold the forward length of rubber backwards, about 100º. This spreads the T-channel apart, enough to slide it over the corresponding metal channel on the rocker panel. A little lube helps.
Sherwood
Old 04-25-2006, 05:12 PM
