High Idle CIS
I'm trying to diagnose a high idle issue on my 81 ROW 3.0 SC. It starts fine, but as it warms the idle creeps up, til it gets to 3000 rpm. Screwing the idle adjustment screw in all the way brings it down to about 2500. If it sits for 20 minutes, the idle comes back down, but after driving again will begin creeping up again. What components should I be looking at here as the culprit? Thanks for any input.
Old 04-30-2006, 10:16 PM
Designer King
Paulporsche's Avatar
WUR, AAR, AAV, decel valve, distributor, and air leaks for starters.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-01-2006, 05:33 AM
Scott R's Avatar
That sounds like a big enough leak to be a intake runner boot, or a hole in the main inake boot, time to get some ether and start spraying for leaks.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-01-2006, 07:27 AM
Danskman's Avatar
My '80 SC did the same thing. It was the AAR (auxiliary air regulator). Replaced it, and it ran like a champ.
Mike
'80 911SC Weissach Edition
'87 325is
'02 K1200RS
Old 05-01-2006, 08:44 AM
Somatic Negative Optimist
Gunter's Avatar
That, and more.
Idle adjustment screw in all the way? That doesn't sound right because it is part of the mixture adjusting process.
Winterfarm: Get a Bentley SC Repair Manual and read, read and learn how the CIS-components work. The AAR would be the first thing to look at with high idle.
You can do a search but why not get a Bentley?
Without knowing the condition of your engine and what maintenance has been done, it's hard to diagnose.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-01-2006, 08:54 AM
