rhk109's Avatar
Anyone using OMP Seat Mounts?
I'm looking for the lowest side mounts available for side mount seats. I'm 6'5" and planning on installing Evo 2's with brackets mounted directly to the stock seat mounts without the sliders. These OMP mounts (733) are described as "low".
Anyone using these or any of the other OMP mounts?
http://www.ompracing.it/detail.html?productcode=/
Yes, I know the link defaults to Italian. I don't know why.
rhk109
'76 911 3.0 Webers
Old 05-02-2006, 06:06 PM
rhk109's Avatar
Good morning...bump
rhk109
'76 911 3.0 Webers
Old 05-03-2006, 04:53 AM
i am using the 733 and if you are 6'5" and plan on using that mount you will be looking at a decent stretch of drilling and grinding. i/m about 6'1 and with my helmet on it is a very tight fit. i didn/t cut out the stock seat mounting points so if it came down to it i could reinstall them. i mounted the 733 brackets to those points. i had to drill new holes in those brackets to facilitate fitting my legs in front of the seat and at the lowest and most steeply angled back position the height is still borderline enough that i/ll be building my own mounts at some point. if retaining the stock mounting points is not a concern for you then cut them out and mount to the floor and they/ll be great. if you end up figuring out something else let me know.
a little of this + a little of that
Old 05-03-2006, 06:23 AM
rhk109's Avatar
felix,
Got any pics? What seats are you using? I've been told that the Sparco brakcets and side mount seat will get the seat significantly lower than stock. I was hoping that these OMP brackets would go even lower.
rhk109
'76 911 3.0 Webers
Old 05-03-2006, 07:47 AM
