Ideal Oil Temperature
Hi!
I just bought a front fender oil cooler and would like to install a fan to keep the temps within spec. Then I realized that I could build a simple motor controller that would use a thermistor and some other electronic goodies to control a fan that would keep the oil at an ideal temperature. In other words, the fan would always be running and the speed of the fan would be proportionate to the Oil temp. I think this would be a better solution than having the fan turn on after a certain threshold, like 250F. Has anyone done this, or can someone tell me the ideal oil temperature we should run? thanks! Brad
'78 911 SC '61 Mercedes 220b '74 Westy 2.0 |
180
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Hi!
But shouldn't you get it above 212 F to get all the H2O out? Unless you meant 180C. Brad
- common fallacy - it doesn't have to reach boiling pt. to volatilize the water! Here's an experiment -- put out a pan of water in your garage -- voila! the water will evaporate until the pan is dry...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off Last edited by randywebb; 05-04-2006 at 05:03 PM.. |
hi!
Touche!! However, if you put enough oil in the pan to cover the water, the water will stay!! I guess above 212F is the point where the water cannot exist (under normal atm. pressure) as a fluid. Brad
180-200° F is a good range to run in, as soon as you shut it off water will start condensensing. Short trips are obviously going to cause more accumulation than long.
