Slumlord
Porsche_monkey's Avatar
89 3rd Brake Light & Alarm
I am just finishing off my '89 cab restoration. Tonight I connected the third brake light and then re-connected the battery. For some unknown reason the third brake light flashed for about a minute or so then shut off.
Is this part of the alarm? What would cause this?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 04-07-2009, 07:08 PM
Slumlord
Bump. Stumped.
84 Cab - sold!
Old 04-08-2009, 06:20 AM
Slumlord
So nobody has ever had their high mount brake light flash...ever?
84 Cab - sold!
Old 04-08-2009, 06:55 PM
Member 911 Anonymous
DRACO A5OG's Avatar
How was the 3rd light connected? OEM harness or spliced in?
'85 Carrera Targa
PCA/POC
Old 04-08-2009, 10:10 PM
Slumlord
It is connected to the OEM harness I believe. It is on a three pronged connector at the rear window. The connector is like the one in the door, a watertight connector. The wire for the trunk light also runs with the brake light wire.
84 Cab - sold!
Old 04-09-2009, 05:42 AM
DRACO A5OG's Avatar
Damn, that is strange?
According to Bentley Guide, the 3rd light's ground is connected to the Engine Lid Light, is that what you meant?
If so, does the lid light work? I am thinking maybe it is a bad ground or an out bulb.
Turn on your lights or just running lights and then check to see it the lid light comes on and off when you operate the assembly.
Just a thought.
You know this ,your 3rd Brake light should have Brown Ground, Black Blue 12 Volt Source and Black Yellow BLS switch
Or I would DVM test the harness coming out of the car, checking each lead.
Sorry can't be more helpfull.
'85 Carrera Targa
PCA/POC
Old 04-09-2009, 06:45 AM
Slumlord
I will check it our this weekend.
84 Cab - sold!
Old 04-09-2009, 10:56 AM
