Always learning
HEy Cali74
How did end up with gasket situation?
Just threaded mine through.
Old 10-21-2009, 07:56 PM
47silver's Avatar
great job and a que
do you apply the por15 directly to the bare metal?
1975 911S Targa
Silver Anniversary Edition
Old 10-21-2009, 08:47 PM
Always learning
you can but I couldn't be bothered waiting for it to dry.... I use Wurth Zinc prime with Wurth texturecoat.
Old 10-21-2009, 09:12 PM
Having done some of the grinding & cleaning that you've done, I can say you are a glutten for punishment. But in the end you know it's been done right. Great job!
47silver. Yes you can apply POR15 to bare metal. I've used the stuff in all kinds of applications. Very good product.
Marv Evans
'69 911E
Old 10-21-2009, 09:14 PM
Always learning
POR is great but its expensive and goes off real fast. I usually keep it for the big jobs.
Old 10-21-2009, 09:19 PM
19 years and 17k posts...
azasadny's Avatar
Wow! Lots of hard work represented here. Great job!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 10-21-2009, 09:22 PM
geoz's Avatar
beautiful work, keep the pictures coming.
cheers
hg
1988 911 Cabrio
Old 10-21-2009, 09:32 PM
78-911SC's Avatar
Great job. A lot of long hours there. Which type of front oil cooler are you using? Any pictures?
PJ
78 911sc Targa
70 911T
Old 10-22-2009, 04:51 AM
Where are you going to put the speedo cable now that there's a fuel line occupying it's space?
regards,
Phil
Old 10-22-2009, 09:52 AM
brads911sc's Avatar
Is there a reason that more people havent done the SS oil lines? I actually have a crushed line and was debating the Air/Heat fix, an Elephant Line, or something just like this. Its a street car. Doesnt really run too hot even crushed, so Im thinking the Heat Transfer issue wont be an issue for me... unless there is something else I am missing... anyone have an opinion?
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 10-22-2009, 11:52 AM
cali74's Avatar
Old thread - it's been a while since I did all this :-)
Thanks for the kind words. The speedo cable is gone with the later transmission that isn't cable driven. Front oil cooler is a B&B, I think there is another thread with pics somewhere.
The SS lines are nice since you can easily build them to suit without fancy tools. Heat transfer could be a problem if your radiators are small... i guess it depends. I originally used rubber wrapped around the lines to protect them from the metal edges, but this year I changed the oil system and added the finned lines from elephant, along with the widemouth carrera cooler and the fan on it. I was worried about sitting in traffic and overheating.
So now I've got the factory style thermostat, finned lines going to the widemouth cooler in the fender with a fan, then going to the big B&B up front.
74 911 with '95 3.6l
Old 10-27-2009, 09:37 AM
