Banned
How to block off Fuel Injector Hole
I have searched and searched I am removing the MFI from this engine and installing carbs. The holes for the injectors are 12mm X 1.5 pitch I thought this would be easy to find a cap bolt I could screw in and red locktite it. All I can find are hex bolts and the head is to big to seal and clear manifolds. I know I can't be the first one to do this so where do you get the cap screws??
Kerry
Old 05-06-2006, 09:49 PM
Paul Thomas's Avatar
I got some here a few months ago to do just that. Nice people, fast shipping. Go to Threaded fasteners, socket heads screws, Part 916 fine.
http://www.metricmcc.com/
My ignition is retarded.
Old 05-06-2006, 10:24 PM
PMO has what you need.
http://www.pmocarb.com/
I found that the best way to contact them was via FAX. I think my set of 6 was less than 25 bucks shipped. They look like they were custom made for the application, and were different (and higher quality) than anything I could find at MMC or any other metric fastener places that we use all the time at work.
Highly recommended.
BTW, hold on to the MFI. I did, and it will be going back on soon enough
Jim
Old 05-06-2006, 11:27 PM
