Rad Hatter's Avatar
9mm spacer on 3.2 Carrera with 8J Fuchs Question::
Want to use some 9mm spacers on the rear of my 3.2 Carrera to fill out the 8J wheel.
The ones I have are flat aluminum.
Q: Do I need extra long bolts or use the existing bolts do you guys think i'll be okay?
Cheers
Euro 1989 Carrera 3.2
Paint Code L 693 Stone Grey
45,000 kms logged
Old 05-08-2006, 08:49 AM
jevvy's Avatar
As far as I remember when I searched on this 7mm was the max that should be used without fitting longer studs - adding longer studs makes it an expensive extra 2mm that im not sure you would notice anyway.
Other people suggested counting how many turns you get with your lug nuts - cant remember how many was suggested to be the minimum, you will have to search for that
'89 3.2/3.6 coupe
Old 05-08-2006, 09:15 AM
Designer King
Paulporsche's Avatar
I think I recall that the rule of thumb is the amount of "purchase" on the stud should equal the diameter.
I have used 6mm spacers (1 per wheel) for years w/ the original studs
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-08-2006, 09:21 AM
I used 6mm with the orginal studs like Paul without problems. I think 6/7 mm is max with original studs.
Bump for Bill V. he will now
87 Carrera Backdate
Old 05-08-2006, 09:30 AM
emcdan's Avatar
I agree that you'll need longer studs with anything over 6mm. I comtemplated this issue also awhile back. I ended using 25mm hubcentric spacers with my 8js. Very full looking. I get just a little rub on the drivers side with a big bump. I personally think that about 12mm or half inch is perfect.
Deutsche Fahrzeuge
78' 911SC
03' 325I BMW
03' KTM 450sx
05' S2000 (daughters)
Old 05-08-2006, 09:56 AM
Rad Hatter's Avatar
Thank you
Thanks guys...you guys are very helpful.
Cheers
Richard
45,000 kms logged
Old 05-08-2006, 04:48 PM
