-   -   While The Engine Is Out... (http://forums.pelicanparts.com/porsche-911-technical-forum/281527-while-engine-out.html)
Amanda 05-07-2006 10:42 PM
Maybe I'm not searching w/the right terms...
Engine's out during a top end rebuild. So what are some things I can (or should) do now that I would likely curse over if I waited until after the engine's back in. Keep in mind I am very much a non-wrench (but I'm hoping to be reformed). :D Thanks.
bell 05-07-2006 10:58 PM
i'm in the middle of an engine compartment cleanup, today was spent cleaning 20 years of grime out and removing most of the engine pad glue...i'm suprised it's still so white, didn't think to take a before pic :D
http://forums.pelicanparts.com/uploa...1147067892.jpg http://forums.pelicanparts.com/uploa...1147067927.jpg
rlh930 05-07-2006 11:20 PM
- check clutch and flywheel
- check CV joints
- replace shifter bushings and shift coupler
- inspect all hoses and replace as necessary
- inspect condition of wiring harness
- clean all goop out of engine bay and (particularly) transmission tunnel area, check for rust
- replace engine compartment sound pad if it is falling apart
- repair any damaged undercoating
randywebb 05-07-2006 11:23 PM
search up past threads for many ideas on this
I'd prob. do a new clutch cable, and for sure clean the engine compartment & put in a new sound pad.
It's a dirty job - here's what I looked like after I finished...
http://forums.pelicanparts.com/uploa...1147069421.jpg
hmd 05-08-2006 01:38 AM
Wouldn't it be wise to 'freshen up' the bottom end at the same time if it has not been done recently?
ianc 05-08-2006 04:10 PM
Thermostat O-ring
Oil light sender
Breather gasket
Main seal
Fuel lines
ianc
autobonrun 05-08-2006 04:32 PM
Replace pressure switch.
Jesset100 05-08-2006 08:13 PM
replace rear shocks
Shuie 05-08-2006 08:22 PM
coilovers, gearbox rebuild, full restoration, etc. :)
