While The Engine Is Out...
Maybe I'm not searching w/the right terms...
Engine's out during a top end rebuild. So what are some things I can (or should) do now that I would likely curse over if I waited until after the engine's back in. Keep in mind I am very much a non-wrench (but I'm hoping to be reformed). Thanks.
SC
Old 05-07-2006, 10:42 PM
one of gods prototypes
bell's Avatar
i'm in the middle of an engine compartment cleanup, today was spent cleaning 20 years of grime out and removing most of the engine pad glue...i'm suprised it's still so white, didn't think to take a before pic
Brought to you by Carl's Jr.
Old 05-07-2006, 10:58 PM
rlh930's Avatar
- check clutch and flywheel
- check CV joints
- replace shifter bushings and shift coupler
- inspect all hoses and replace as necessary
- inspect condition of wiring harness
- clean all goop out of engine bay and (particularly) transmission tunnel area, check for rust
- replace engine compartment sound pad if it is falling apart
- repair any damaged undercoating
Roger
'87 930
'73 911T
Old 05-07-2006, 11:20 PM
randywebb's Avatar
search up past threads for many ideas on this
I'd prob. do a new clutch cable, and for sure clean the engine compartment & put in a new sound pad.
It's a dirty job - here's what I looked like after I finished...
Old 05-07-2006, 11:23 PM
hmd hmd is offline
Wouldn't it be wise to 'freshen up' the bottom end at the same time if it has not been done recently?
76 Carrera 3.0 (Group Sc)
Old 05-08-2006, 01:38 AM
ianc's Avatar
Thermostat O-ring
Oil light sender
Breather gasket
Main seal
Fuel lines
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 05-08-2006, 04:10 PM
autobonrun's Avatar
Replace pressure switch.
Old 05-08-2006, 04:32 PM
Alii&Maui
Jesset100's Avatar
replace rear shocks
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 05-08-2006, 08:13 PM
Licensed User
Shuie's Avatar
coilovers, gearbox rebuild, full restoration, etc.
Old 05-08-2006, 08:22 PM
