| Registered Join Date: Nov 2005 Location: Cincinnati
				pushing speedo cable thru trans tunnel
			I'm preparing for an engine drop on my 3.2L...there's a rubber grommet that surrounds the speedo (sensor) cables in the transmission tunnel. I know the cables have to be pushed thru before the drop. The little plastic covers on the speedo wires won't fit through the hole with the grommet...Should I just push the entire grommet/plug w/ the wires thru the hole? Cut the grommet etc...? Seems like a cheap part to replace... mostly concerned with preserving the wires and plastic covers. Any ideas...
				__________________ 86' 911 Carerra Last edited by slotcar; 05-10-2006 at 08:56 PM.. | ||
|  05-10-2006, 08:53 PM |
| Registered Join Date: Aug 2004 Location: Sunny San Diego
			Take a flat blade screwdriver and pry out the grommet.  Remove the entire assembly. It's easy to pry the grommet back in.
				__________________ David Nguyen 1987 930: 2700 lbs, 408 RWHP/405 RWTQ 930 pics: http://alturl.com/899f9 930 Engine rebuild pics: http://alturl.com/25qcy | ||
|  05-10-2006, 10:00 PM |
| Registered Join Date: Sep 2004 Location: London UK
			why dont you just disconnect the sensor leads from the tranny then you can just leave the gromet and wire where it is - I wish I'd done that cos the grommet is a bear to get back in.
				__________________ '89 3.2/3.6 coupe | ||
|  05-10-2006, 10:49 PM |
