Gauge questions
In my 83SC it is obvious the tach, speedo, and clock are all new or restored (bright orange indicators, numbers crisp and clear and the clock is a quartz clock which I don't think is OEM). the left 2 (fuel and gas level and temp) are faded, they get condensation behind the glass etc. My druck pressure/ oil pressure is of course rated 0-5. At highway cruise speeds it runs stead at 3, when I run the tach up higher say accelerating on a on ramp it runs up to 4 and at idle is sets at 1. Does this sound normal? Also I can't get my clock to work altogether like I said the condition of the clock looks great. Can I test the wires coming into it with a hot light tester or should I use my multi meter (which I just bought this weekend and not totally sure how best to use it). Thanks
83SC black on black 01 Chevy S10 08 Buick Enclave |
Your oil pressure sounds fine. About all you can test on the wiring to the clock is whether it has power and a good ground. If it has power and a ground and it doesn't run, the problem will be internal. I'd use the multi meter. Just read the directions-they're easy to use for simple tests like this.
JR |
Thanks allot
