JeffO's Avatar
Kudos to Mobil 1 75w 90 syn gear lube
Just changed out the tranny fluid to baseline my Carrera, and must say that my tranny shifts real nice now.When it warmed up the shift feel was excellent. I think it was the first change out since new, so 86000 miles and 19 years has to make a difference. Also I bought a pump from NAPA for 7 dollars and it made for a real easy fill.
"The smaller the fine print, the larger the risk."
1988 911 coupe
2008 VW R32
2004 530I
Old 05-10-2006, 05:37 PM
Weaver's Avatar
JeffO, I was just about to do the same on my '88. I can't seem to find where to fill the box. I looked it up in my Bentley manual, but it seemed vague. Very unlike Bentley. Anyway.
Weaver
'88 911 Targa
'03 911 Turbo, X73 Susp.
'13 Panamera GTS
PCA member Central Indiana
Old 05-10-2006, 05:46 PM
Excuse my ignorance but is that a G50 or 915 in the 1988?
Old 05-10-2006, 05:47 PM
I still can't locate a 17mm allen wrench. Been to Checker 2x...
1985 3.2 Coupe
Old 05-10-2006, 05:49 PM
JeffO's Avatar
Its the G-50, and the fill plug is on the top side of the tranny. Open this first. Then drain the fluid. That way you do not drain then realize you can not fill.
1988 911 coupe
2008 VW R32
2004 530I
Old 05-10-2006, 05:51 PM
JeffO's Avatar
It's a ten millimeter allen. I had one in the factory tool kit , but bought one at the hardware store so as not to bugger up the OE one.
1988 911 coupe
2008 VW R32
2004 530I
Old 05-10-2006, 05:56 PM
Did you use this one:
http://www.lufteknic.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=Mobil75-90SHC&Category_Code=lubricants
or the Autzone available one?
brant giere
2005 996 cup
1991 964 euro cup (Larbre #28- race
1987 carrera 3.2-street/de car
1962 Austin Healey 3000
Old 05-10-2006, 06:10 PM
JeffO's Avatar
I bought the Autozone 1 quart bottles, but when I checked the Mobil web site I only remember seeing one choice.
1988 911 coupe
2008 VW R32
2004 530I
Old 05-10-2006, 06:21 PM
Robby Robinson's Avatar
I also use Mobil 1 in my G50. I drive my car year-round and in cold weather I believe it has made quite a difference.
Fill plug was on the driver's side of the tranny, and drain hole on bottom. I used a long piece of vinyl tubing and filled directly from the bottle. When oil starts to run out of the fill hole, stop. A full trans case should be just up to the bottom of the side hole.
88 Carrera cpe
mostly stock
Old 05-11-2006, 12:04 PM
So is it a 17mm allen or 10mm allen to remove the plug? I read it was 17mm...
1985 3.2 Coupe
Old 05-11-2006, 12:42 PM
1985 takes a 17 mm...
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-11-2006, 12:46 PM
Thanks Wil
1985 3.2 Coupe
Old 05-11-2006, 12:55 PM
Wavey's Avatar
I've found that "level with the bottom of the fill hole" is different if only the back of the car is raised, vs raising the whole car. Definitely holds more with the car level, so I raise the whole car on jack stands when doing this. Of course a lift would do the same thing...
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 05-11-2006, 01:00 PM
Breaker Bar (longer the better) do not try to remove the filler or drain plug without a long breaker bar...hex socket, and PB blaster (you do not want to strip those plugs). Best to replace with new plugs if you have the chance...
86' 911 Carerra
Old 05-11-2006, 01:03 PM
Bill Verburg's Avatar
'85 & '86 Carrera are 915, '87 - '89 are G50
Bill Verburg
Old 05-11-2006, 02:57 PM
