Virginia Rocks!
VaSteve's Avatar
Talking The human torque wrench?
I have been doing a lot of work on my broken car and have been doing a lot of looking up torque values in the book. I have found that occassionally, I will tighten up the bolt by hand and when hitting it with the torque wrench, I'm not far off. Other times (usually the smaller bolts) I'm way off.
Since I have been huffing too much brake cleaner in the garage, I have been thinking theory.
For those of you that have been at it a long time, or especially those that do this professionally, how accurate are you as a "human torque wrench"? Do you ever not go back and check because you're that good?
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 05-09-2006, 11:41 AM
Registered Cruiser
jorian's Avatar
As soon as I hear that click in my elbow I know I've gone far enough...
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 05-09-2006, 12:32 PM
chrisp's Avatar
I find that if I am using the same length wrench on the same bolt I can be pretty consistent. In a previous life I used to torque bicycle bolts pretty regularly and could nail a 35 ft/lb crankarm bolt pretty consistently.
Today I find that I will normally bring a lug nut up to 85-90 ft lbs before I confirm with the wrench that I am right wehere I want to be by hand.
'83 SC
Old 05-09-2006, 12:38 PM
buster73's Avatar
After some years of wrenching you certainly get a feeling for the typical torque range. For non-critical bolts I usually don't use a torque wrench anymore. However I always use a torque wrench for all critical bolts (engine, tranny, CV's, brakes, suspension, wheel nuts, seal/gasket areas). My experience is that small fasteners tend to be over-torqued while larger sizes remain under-torqued if no torque wrench is used. Not worth the risk.
Regards,
Guenter
73.5 911T, mod
Old 05-09-2006, 12:51 PM
bigchillcar's Avatar
lol..jorian.
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-09-2006, 12:58 PM
David's Avatar
From the Machinery's Handbook
Method Accuracy
By feel +-35%
Torque Wrench +-25%
Turn-of-nut +-15%
Preload indication washer +-10%
Bolt elongation +- 3-5%
Strain gages +-1%
I go by feel a lot more than I probably should.
Old 05-09-2006, 01:59 PM
Only on non-critical stuff do I use a human torque wrench. For all important stuff (brakes, suspensions, engine, tranny etc) a calibrated torque wrench is the way to go
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-09-2006, 03:24 PM
Kantry Member
oldE's Avatar
A friend of mine is 'that good'. He is a mechanic.
Years ago, he did a water pump and timing belt change on my 924S. I had a good drive home and then freaked out while reading the warning in the manual to the effect, "If the timing belt is replaced, under no circumstances should the car be operated until timing belt tension can be verified with Porsche part #blah blah..."
I called the nearest dealer and talked over the situation. They suggested if it hadn't slipped or slapped, it might be close enough to allow me to drive it in to their shop to check the tension.
When they put the guage on it, it turned out my friend had nailed the specification, just by 'feel'!. I was impressed.
Les
Best
Les
Old 05-09-2006, 03:27 PM
Don Plumley's Avatar
My rear axle nuts required 300ft-pounds. I weigh about 150, so I stood on a cheater bar out 2 feet from the axle nut. 300 foot-pounds. Is that what you mean by human torque wrench?
Don Plumley
M235i
Old 05-09-2006, 04:18 PM
Virginia Rocks!
VaSteve's Avatar
Les,
I spend a lot of time on the 944 side of the site...that's what I have been fixing. There is a whole science/black majic around just twisting the belts to get the right tension.
David,
What the hell is "turn of nut"?
Old 05-09-2006, 07:15 PM
tdatk's Avatar
Steve,
Funny thing bout the 944/928's is that as soon as you service the timing belt the water pump siezes up and really torques your nuts.......
Tim
Tim
82 SC
90 C2
Yasowatt
Old 05-09-2006, 07:41 PM
Just like with most skills in life, some guy's just have better mechanical ability.
A natural sense for how stuff works and how tight it needs to be.
Old 05-09-2006, 08:24 PM
Probably not accurate to recheck unless you have comparable specs for bolt stretch. Torque is measured while the fastener is rotating, not after. Break-away torque is higher than the true torque applied.
Sherwood
Old 05-09-2006, 08:38 PM
Sherwood
True. If you torque by hand and stop and then switch to a troque wrench, the amount of torque to move the fastener further will be higher than the same torque wrench would have clicked at it it had been used in the first place. Thta is why you should always keep the torque wrench moving in a smooth motion when approching your value.
-Brian
Old 05-10-2006, 10:28 AM
Navin Johnson
TimT's Avatar
"Turn of Nut" is a methed for tensioning bolts that is recognized by AASHTO, AISC, and other standard writing orgs. its more commonly used for large structural fasteners..
typically a nut is snugged by hand with a standard spud wrench ( usually taken to be 150 ft/lbs), then the nut is turned "X" amount more, depending on the thickness of the parts being bolted.
This method is used on some automotive fastners also, ie some BMW head bolts...they actually have you torques the bolt to a value, then rotate the nut 90 deg more.
'69 911 GT-5
'75 914 GT-3
and others
Old 05-10-2006, 10:40 AM
As do stock rod bolts in the 911.
-Brian
Old 05-10-2006, 10:45 AM
and head studs on the 911.
Old 05-10-2006, 11:33 AM
