-   -   Any VW Bug guys out there? (http://forums.pelicanparts.com/porsche-911-technical-forum/281998-any-vw-bug-guys-out-there.html)
fastbacker 05-10-2006 11:32 AM
I've got a 69 Bug and was wondering if rims from a 74 4-lug 914 would fit on it.
Thanks-
Craig Backer
cbeers 05-10-2006 11:36 AM
Long time ago :)
I think with the body style change from the classic old style ('67 and prior) to the newer style ('68 and on) also meant 5 to 4 lug change.
Not 100% sure, but that's how I remember it.....
-Chris
jorian 05-10-2006 11:43 AM
'widebody' on this board is a vw guy. He has a site www.vintagebus.com with alot of cool stuff on it.
Vin-barrett 05-10-2006 11:49 AM
they fit
widebody911 05-10-2006 11:58 AM
I'm a VW guy, but I'm also a wide-5 purist :)
1960 double-door panel
1961 double cab
1968 single cab
1956 sunroof bug
1957 hardtop bug
1966 hardtop bug
fastbacker 05-10-2006 12:32 PM
1961 double cab
1968 single cab
1956 sunroof bug
1957 hardtop bug
1966 hardtop bug
What's a wide-5 purist?
dougcl 05-10-2006 12:34 PM
"I'm a VW guy, but I'm also a wide-5 purist "
ha ha
M491driver 05-10-2006 12:54 PM
Here's my last VW, a '63 single cab. Notice the Fuchs. It has the wide-five pattern but was adapted to wear the Fuchs. It now resides in B.C.http://forums.pelicanparts.com/uploa...1147290826.jpg
Jeremy Cottrell 05-10-2006 01:07 PM
4 lug 914 wheels will fit a 4 lug VW.
defcon65 05-10-2006 02:43 PM
Wrenched on Vdubs and dreamed of 911s in my youth. Ain't going back, but I still love the hollow sound of that exhaust whistle. New beetles are an abomination - who'd want something that practical?
Jeremy Cottrell 05-10-2006 03:08 PM
My wife loves her new Beetle. I keep trying to talk her into some 17 inch BRM wheels, give it a retro- drag bug look. Then I could drive it too......
NY65912 05-10-2006 04:04 PM
How about going the other way, Porsche whels on a Bug? Here's mine.
http://img.photobucket.com/albums/v1...b/DSCN5852.jpg
dbox 05-10-2006 04:24 PM
Last friday I saw a pristine bug with fuchs wheels. it kinda made me want one
911 in SC 05-10-2006 04:37 PM
Jim! Nice!!! Did you have it while in SC or was this in your CA days?
Yeah, I've owned several bugs in my earlier days of driving. I've owned a '74 Super, '68, '71 and lastly a '58. In a way, I miss them all, but I miss the '58 the most.
Mike
lateapex911 05-10-2006 04:51 PM
Man, that thing is COOL! They shoulda made the logo bigger though...tough to read if you're more than 2 or 300 feet away,...;)
RRico 05-10-2006 05:00 PM
I just started a flat-6 conversion on my bay.....http://forums.pelicanparts.com/uploa...1147305648.jpg
M491driver 05-10-2006 07:06 PM
Mike
Brought it out from Newport Beach to SC. Not many people in the Southeast had ever seen one so it always drew a crowd. It's probably the only car I ever regret selling. I guess it shouldn't be a surprise how many Porsche folks are or were into VWs. While I was into Vettes I always had a VW around like a 64 21 window slide top, '57 oval, '66 with a 2165cc (scared me to death) and a '63 bug (first place at Bug Jam Nationals)
dvkk 05-11-2006 01:26 AM
Re: Any VW Bug guys out there?
As stated above, the wheels will bolt on. However, the offset is not ideal for a Beetle (perfect for Ghias). Your tires will be inset further than stock, causing them to rub on turns. You will need to set your steering stops a little further out, increasing your turning circle.
A 10mm wheel spacer will help a lot, but you won't be able to use the stock wheel bolts if you do. longer studs and nuts will work, or you can search for some original VW 411 wheel bolts that are longer. Some early Golfs also use a longer M14 wheel bolt, but with a 17mm head instead of the normal 19mm hex the Beetle has.
GothingNC 05-11-2006 04:50 AM
Original 1959 356 Rims fit on a Thing:D
URY914 05-11-2006 05:30 AM
That will be sweet. I've seen -6 Bus's do wheelstands.:eek:
