can't search archives, show me a painted decklid grille
I couldn't search the archives. It only goes to catalouge selections. Has anyone painted their dull decklid grill in either semi gloss or gloss, body color, radical treatment?
Any help and photos appreciated.
78SC coupe, Silver Metallic |
using the "search" button on Top/Right?....works better than the text field location on bottom/right....
- Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Banned but not out, yet..
I repainted mine a semi-gloss back (BBQ black) as well as the oil lines, and wiper arms. The oil lines and wiper arms are indistinguishable from new and the grill looks great for not being annodized. None of them are worthy of a pic since all of it looks pretty bone stock.
An air cooled refrigerator. ‘Mein Teil’ |
But the search function at the bottom should search the forum... and DOESN'T. Just get odd ball stuff from the catalog.
Ben Fegan 1988 Carrera Targa |
Recreational User
You have to click the "Search" button just below the Order Status link in the upper right corner of your screen.
Ok... I see. However, the lower right box says "search this forum"?
I did mine this fall. Painted with black semi-gloss enamel. Looks great. I'll take a picture and post later tonight. It makes a huge difference. You'll be happy you did.
Mike '82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar. |
Thanks. I'm going to give it a try. (painting it)
Here is a picture of the painted grill.
The picture is a little dark, but I think you can see how the surface is nice and even satin black. It looks really nice in daylight
Mike '82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar. Last edited by VFR750; 03-04-2006 at 04:47 AM.. |
That's the look I want! Excellent. Was it from a spray can?
Yes, humble satin black in a can. Indoor/Outdoor enamel.
Rustoleum or Krylon, can't remember which one, I tossed the can a while back.
Wow that looks good. That'll be the next mini project- thanks
Bob Piper 78 911SC "Bullseye" SOLD 00 540i 02 CBR 954RR 98, 00, 03 sons |
Did you remove the grill to paint it or did you use a huge amount of tape and paper to avoid overspray? If it was removed, how difficult is that and did you have to remove the a/c components from the underside of the decklid?
PS: the car is an 86 coupe, no whaletail
Rustoleum Satin Black aerosol (p/n 7777) works great for this.
Jack 2007 GT3 gone but not forgotten: 1987 Carrera IROC backdate, '89 Carrera M491, '96 993, '93 964 RSA(two), '00 996, '97 Boxster, '79 911SC, '78 928, '76 924, '75 914, '74 911, '74 914, '72 911E, '72 911T/V, '71 911T, '70 911T, '66 912, '65 356C, '61 356B roadster, '60 356B |
Remove the grill. By the way I use the foamy formula 2000 tire spray on my grill and it comes out nice. Anyways... if you are going to paint it I would recommend removing it and cleaning it really good to ensure there is no wax or other build up, otherwise you paint will start flaking off. Also I would recommend a special bumper and trim paint as the plastic parts shrink and expand depending on the heat and exposure to sunlight.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Immature Member
Definitely remove the grill or your next post will be 'removing black paint from engine compartment?"
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
Repaint it - no problem - use semigloss or satin black.
Senior Member
Projects: 911 -72T EFI "964-look" "Smoky" 914 -71 1.7 D-JET "Rusty" |
Definitly remove the grill. Much easier to clean. I don't think you could mask it in place.
You don't have to "remove" the condensor. But you do have to unbolt it from the lid to gain access to the nuts.
