MY 84 CARRERA What Do I Have?
hello, i now have a 1984 Carrera that was sold new in Germany. i am putting this in the "TECH 911 " area for a reason, so please bear with me. the car is euro with the trans cooler, USA spec headlights, and taillights. i have the following questions:
1) my car has an o2 sensor. it had a cat on it and now has a bypass pipe with the 02 sensor hooked up. the wire is broken to the sensor, and when the car warms up, the idle goes up and down between 800 and 1200 in a cyclic manner. friend says its the computer sensing the car is warmed up and its trying to set the mixture with the lack of 02 sensor signal. if the car was sold as a euro with no cat, why would the computer know to look for the signal? i am going to fix the wire and then replace the sensor, but the car did not do this until a few days ago, and now the wire is broken.... thoughts? 2) my car is said to be a special order, special wishes car. what the heck does that mean exactly , and how do i know? the Moss Green and the green dark green / black interior are special order. i have the complete tool kit, the manuals( in German with the dealer / service stamps) and the English manual. the car has a emergency triangle in the box and a complete, unopened medical kit in a plastic "PORSCHE" bag. are these items correct for a Euro car? do they help with resale? why the heck is there a huge medical kit!!! 3) next: i am of course posting pics, who is the guy whose name is on the metal plaque? the car has DOT EPA placcards on it, a added VIN to the left side of the windshield, and i have a clear title. anything special about this car???? i did get it cheap!!! ![]() 4) any help on the 02 issue would be great. the idle is erratic when its warm, and i dont think its DME or head temp sensor related. i am just wondering why a German spec Carrera would have the ECU looking for a 02 signal, unless the car was ordered that way for the tax credit. ![]() ![]() ![]() |
more pics
I also have an 84 RoW Carrera, the decal under the hood is on mine but my epa/dot plate is very different from yours. I am guessing they vary from importer to importer. I also have the VIN glued to the drivers windshield pillar.
I am very curious to find out that is a "special wish car" I love the color of your car, very nice ![]()
1984 RoW Carrera Cab 1986 944 Turbo-sold for new home 2005 Suzuki Hayabusa-sold for new home 1986 928s 32V-sold 1978 911 Targa-sold 1987 924S-sold |
sounds like a federalized grey market car...special wishes means the color and/or interior were special request...as far as the 02 in concerned...not sure...but I would imagine during the federalization process in order to meet federal emission laws a US computer had to be installed thus causing it to search for the sensor.
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
The name on the DOT/EPA tag, as indicated, is the private importer who took responsibility for federalization. I have a similar tag. I'm guessing they vary state to state as to style and placement.
Your color code is Moss Green Metallic. There were only five standard colors in 1984. "Special wishes car"? I don't know, but I would think all Porsches are. Lovely color, and also the matching Fuchs.
1984 RoW Cabriolet - GP White |
The 02 sensor has no effect when cold and can take up to 3 mins. or more to heat up. Cheers, Joe |
i am going to fix the wire and use the part number on the sensor itself to get another one. its a one wire sensor, should be a pretty common part. compared to old Lamborghini parts prices and tight spaces, these P cars are cheap and a pleasure to work on! as far as the car bieng "special" i think its just a green 911 that found me.... its better than the ugly purple 911sc i posted about , along time ago on here ! ![]() |
by the way... i really REALLY dislike the headlights.... i am saving pennies for a set of H4's. shame there arent any used ones!!!
Go for H1's. Maybe change the Turbo tail for a Carrera one.
j.p. |
Student of the obvious
I thought Special Wishes had it's own option code. Here's how your options decode:
Code Option Description 261 Passenger side mirror - electric - plain 441 Fader, antenna booster, 4 speakers 441 Radio speakers and antenna amplifier 468 Graduated tint windshield, green side glass 474 Sport shock absorbers (Bilsteins) 533 Alarm system 559 Air conditioner (with front & rear condenser) 650 Sunroof
Lee |
Try cleaning your idle control valve with a little wd40 or whatever is close to that it you still have the problem it is the ICV or a vacuum leak. Most likely the ICV give us more info on when it runs for a bit or is warm.
Meanwhile, you could always take your time to hunt down that vacuum leak. Joe |
Modes of Transportation: 1984 Porsche 911 Targa 2003 VW Jetta GLI |
perhaps its something i did while i was in there !!! ![]() thank you for all the replies. |
added.... idle changes from 800 to 1500 every 2.5 seconds in a pattern, up down , up down. this is very rapid. got to be one of the sensors !
Been down that road too many times on my 86 3.2. I can recreate that same senario every time by adjusting my idle up too high. Cheers, Joe Last edited by stlrj; 05-11-2006 at 06:19 AM.. |
thank you Joe, when i have time to drive the car again i will see what i can accomplish with the idle setting. perhaps the car had the vaccum leaks for some time. now that they are fixed (?) the idle is hunting for a happy spot! |
I had a hunting idle on my '84. Turned out to be the throttle microswitch.
It's very easy to test. This thread has info: '84 3.2 eratic idle
Lee |
