2 quirky problems.
The first problem is that as of last night my seat belt warning buzzer won't go off. Is there anyway to disconnect it?
Second problem.....my interior light (Targa) only lights up when the passenger door is open, not the drivers door. Any help on these 2 irritating problems is GREATLY appreciated. Thank you.
1964 Blue 356SC Coupe (Disintegrated from rust) 1970 Orange 911T Targa 1977 Black 930 Turbo 3.0 -1988 Carrera slant nose (Sold) 1996 Black 993 Cab.(Sold, and back in Germany) 2006 Slate Grey Carrera S coupe |
On the light issue, check to see that the door switch, located in the front jamb between the hinges, is operating correctly and is grounding properly. The boots can rip. water gets in and the contacts can oxidise.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Designer King
There is a relay behind the fuel level gauge that can be removed to silence the buzzer.
For the light, make sure the light fixture is in the correct position. It rocks into 3 positions. One is so it activates when the door opens. Check the light bulb itself, the wiring, and the fuse.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
