911 Targa, 1976 Rear Axle Removal, I need help.
Gentlemen,
I'm trying to remove my rear axles for a cv joint replacement project and I can't remove the dam things. This is what I've done thus far:
1. Removed tire
2. Removed cotter pin on axle nut
3. Spayed some PB blaster to help with removal
4. Attempted to loosen with my impact wrench then later a breaker bar, what am I doing wrong?
Any suggestions is greatly appreciated.
Thanks,
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 05-14-2006, 11:03 AM
Put a long pipe over the breakerbar. I use a 3/4 inch breaker bar with some roll cage piping over it. Have someone stand on the brakes while you loosen the nuts. They are on there with about 300 ft/lbs.
-Andy
Old 05-14-2006, 02:47 PM
Home of the Whopper
Put the tire back on, put the car back on the ground, then use a big a$$ breaker bar.
1968 912 coupe
1971 911E Targa rustbucket
1972 914 1.7
1987 924S
Old 05-14-2006, 03:26 PM
Thank you both for your input, I just broke my craftsman 1/2 inch breaker bar. I'll try your suggestions and let you know which one worked. They sure are on there pretty tight, how do I confirm proper torque, my craftsman torque wrench does not go that high.
Best Regards,
Alex
Old 05-14-2006, 07:58 PM
This is in the wrong forum. On a 1976 the wheel hubs aren't involved in CV joint/half shaft removal/installation. Replace the cotter pin and whatever else you removed. The go to the transmission side of the half-shaft (axle) and the clean out the heads of the six 8 mm screws securing the CV joint to the transmission output flange. Loosen and remove the screws and the CV joint will separate from the flange. Then go to the back side of the wheel hub and repeat. Support and keep together half-shaft and CV joint sections as they can come apart. Repeat for other half-shaft.
I recommend you invest in at least a Haynes 911 manual and the 101 projects book.
Cheers, Jim
Old 05-14-2006, 08:19 PM
Thanks Jim,
I'll give tis a try, I was working off my Bentley manual and it should that the axle nut needed to be removed but. The manual is for my engine and not the body but I thought the axle section would be the same, I was wrong. Thanks!
Best Regards,
Alex
Old 05-15-2006, 06:32 AM
Yup! The inner cv bolts on the axles did the job!
Thanks a million to all for your help.
Alex
Old 05-15-2006, 06:38 PM
Just a note on CV reinstallation. Make sure to accurately torque each of the allens when you replace the axle. I believe the torque on the '76 was 34 ft/lbs, but you should double check that with the Haynes.
Old 05-16-2006, 04:18 PM
Thanks again for your help, I'm planning to replace all the allen bolts with new ones as well. I've read that it's cheap insurance.
Best Regards,
Alex
Old 05-16-2006, 07:58 PM
If the wrenching features (hex inside heads) are in good condition and the screws uncorroded they may be reused. Spend your money and effort adding 8mm Schnorr lock washers under the screw heads and cleaning all the grease out of the female flange threads and the flange mounting surfaces. As mentioned already, torque the screws properly with no grease or oil on the threads.
Old 05-16-2006, 08:06 PM
Jim,
Thanks for the advice, I'll purchase the washers. Does our host sell them or where can I get them?
Best Regards,
Alex
Old 05-17-2006, 09:40 PM
