rbuswell's Avatar
Different sized transmission plugs
Car is 1982 SC Coupe. Transmission and engine numbers match the COA. First time changing the fluid and I went to Wayne's book and it said 17 mm wrench, both plugs. Jack up the car and sure enough the drain plug is a 17 and the side plug is much larger. Side plug is on driver's side and looks exactly like the picture in my Bentleys. That book doesn't say what size it is either. What size do you guys suppose the side plug is?
1982 911SC
1987 924S
Old 05-27-2006, 03:06 PM
rbuswell's Avatar
False alarm
It must have been an optical illusion but I tried the wrench again and it worked.
1982 911SC
1987 924S
Old 05-27-2006, 03:13 PM
