mkimber's Avatar
Replaced MY Front Hood Struts Today
I finally got tired of my front hood hitting me in the head or using a broom stick as a prop for the '87 Carrera. Maybe this has been said already, but I highly recommend Bob Tindel's article in the Tech Info Center to anyone thinking about replacing their front hood struts. What could have been a long and frustrating afternoon (particularly installing the pin and retainer on the driver's side) turned into a rather straight forward DIY, at least for someone who is mechanically challenged more often than not.
Michael
1987 3.2 Carmine Red Carrera
1995 Midnight Blue 993 C4
1957 Silver Speedster Outlaw (replica)
Old 05-13-2006, 05:29 PM
the trick for doing this job is having a pair of needle nose pliers with a bend at the end (90*) for putting the pin in and the retaining clip on likely one of my most used tools. especially usefull on the driver's side.
a little of this + a little of that
Old 05-13-2006, 05:32 PM
mkimber's Avatar
Looks like we used the same approach, Felix. I used a very long and slightly curved pair hemostats for the pins, and dental floss to tie to the retainers so I could find them if I dropped them into the "black hole" or they flying across the garage (Bob Tindel's suggestions).
Michael
Old 05-13-2006, 05:41 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Wish I'd read that article. lol!
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 05-13-2006, 05:56 PM
RDR911's Avatar
I didn't read the article, but my wife has small hands, so she finished the drivers side for me, what a gal!
1981 911SC Euro
Trial & error, mostly error, I'll figure it out.
Old 05-13-2006, 06:24 PM
Driver Ed's Avatar
Exclamation
I used hemostats for the pins, too, but didn't tie anything to the retaining clips. I was done in less than twenty minutes... or about an hour if you count the time spent looking for and then fabricating a new clip!
2000 Porsche 911
1982 Porsche 911 SC Targa
Old 05-13-2006, 07:41 PM
LakeCleElum's Avatar
Agreed, the article was quite useful.....Was my 2nd hood upgrade...The first was from a Yardstick that finally broke to a piece of 1 X 4 lumber.......
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 05-13-2006, 08:33 PM
rs6er's Avatar
Any advice on doing the rear?
John
Old 05-14-2006, 05:55 AM
Driver Ed's Avatar
The rear deck is essentially the same job.
2000 Porsche 911
Old 05-14-2006, 02:32 PM
Couldn't you drill the mounting pins to fit cotter pins instead of using the PIA OEM circlips?
Old 05-14-2006, 08:50 PM
mkimber's Avatar
Cotter pins sounds like a good alternative. Wayne's book also suggests using nuts and bolts.
Michael
Old 05-15-2006, 12:17 AM
Non Compos Mentis
I recently changed the passenger side, and since the hood would stay up on it's own, decided that the other new one is now for next time I change the passenger side only.
Old 05-15-2006, 06:40 AM
Driver Ed's Avatar
I don't know how cold it gets where you are, but those things don't work as well when it's cold out and you may find you need both.
2000 Porsche 911
Old 05-15-2006, 11:33 AM
The idea of using dental floss is awesome. Wonder if it would work on nuts. Although the tolerances may be too small. Interesting.
Q.
2004 996 TurboS Cab
2005Cayenne Turbo S
1988 930 Turbo Cab
2004 BMW M3
2007 Range Rover Sport
Old 05-15-2006, 01:34 PM
rs6er's Avatar
I figured that one out on my own after one of the clips fell into the abyss.
Old 05-15-2006, 01:42 PM
buster73's Avatar
I'm finally done with hood struts and "lifetime" warranties. Converted engine and trunk lid to Carbon Fiber struts. Not planing to touch them again for the next 30 years.
Regards,
Guenter
73.5 911T, mod
Old 05-15-2006, 01:46 PM
