Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
Hawk pad wear
Hey Guys,
I have a set of Hawk HP plus pads on the 912-6, carrera calipers and rotors, stock MC, with a stock proportioning valve.
I have 3-4 weekends of wear on the pads, all DE's. Front pads are 1/4" still, rears are down to 1/8".
I've never seen rears wear down faster than fronts, is this normal with track use?
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 05-15-2006, 05:08 AM
Bill Verburg's Avatar
It's normal for Carrera calipers, they are heavily rear biased, when line pressure is > 33bar the oem p/v will cut the presssure to the rear by 46% shifting bias, applied brake torque and pad/rotor wear to the front. But whenever the line pressure is < 33bar the rear is doing more than it's fair share of the work. If you have nice squeeky pads(you should) then you can actually hear which end is working and the shift back to front, front to back.
Your case sounds a bit worse than usual, I would inspect the fronts to be sure that everything is working nominally, including the lines. But if that is all ok then you will just live w/ it.
Bill Verburg
Old 05-15-2006, 02:14 PM
or....get on the brakes harder !! ( to activate the proportioning valve).
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-15-2006, 02:38 PM
Southern Class & Sass
Dixie's Avatar
Very odd. My '88 Carrera goes through about two set of front HP+ pads for every rear set.
Does your 912 employ a proportioning valve?
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 05-15-2006, 03:33 PM
Stahlwerks.com
jhelgesen's Avatar
So how do I check if my proportioning valve is working correctly? I got it as a freebie from a pelican when I first installed the carrera brakes.
Car stops great on the track, never fades. Been standing on them harder and harder with each weekend I go.
Rob, will you be at CMP this weekend?
John Helgesen
Old 05-15-2006, 06:59 PM
Dixie's Avatar
Hi John,
I will be at the track Friday. I'm skipping the PCA DE this weekend. We're going to the beach instead.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 05-16-2006, 04:40 AM
