-   -   Turbo cool down - Turbo timer (http://forums.pelicanparts.com/porsche-911-technical-forum/283135-turbo-cool-down-turbo-timer.html)
drophit 05-16-2006 07:17 AM
What do you guys do to facilitate the 2 min turbo cool down after driving?
Has anyone used any of the aftermarket timers? IF so which is best?
Z
1994 965
slow&rusty 05-16-2006 07:18 AM
I leave it running and time it....
javadog 05-16-2006 07:47 AM
The last mile or two of driving, I stay out of the boost and drive like a granny. Then I idle for a minute or so. Never had to replace a turbo yet.
JR
tsuter 05-16-2006 08:00 AM
You mean at the track??? Or just motoring around to the mall and Starbucks for latte???
Emission 05-16-2006 08:15 AM
On the streets, and at the track, I just drive without the turbo for the last five minutes (cool down lap at the track). It's pretty easy to do if you are conscience about it.
javadog 05-16-2006 09:13 AM
tsuter,
Both. Obviously the track would get a more thorough cool down, for the turbo and the brakes. Still, street usage gets a gentle warm-up and gentle driving before shut-down. Not a bad philosophy with all cars, turbo or not.
JR
tsuter 05-16-2006 09:19 AM
That's the whole point.....you don't need it...for track or latte runs...
tsuter 05-16-2006 09:25 AM
Of course I have advocated one of these for the DIY twin setups running KO3s or equivalents...
http://forums.pelicanparts.com/uploa...1147796726.jpg
RarlyL8 05-16-2006 09:48 AM
What is that ?
Emission 05-16-2006 09:52 AM
Originally posted by RarlyL8
What is that ?
I'll second that. :confused:
drophit 05-16-2006 11:26 AM
SO let me be sure i am straight, if i stay outta the turbo it does not need cool down? I am hardly on it anyway, so i should just be able to turn the car OFF as soon as i am stopped? I thought you had to let it idle no load for 1 min or so either way?
Also, i mean around town etc. I go to the store form home 4 mile trip or so and i gatta sit there and wait for the 1min, kinda annoying, would rather have a timer, then i could jump out right away and not be hassled with cool down etc...
Emission 05-16-2006 12:05 PM
When the turbo is compressing air, it is getting HOT. If you aren't using boost, than you aren't compressing air... and the turbo just gets up to normal exhaust-type temps. No big deal.
I have never had to "wait" for mine to cool down - I just drive mellow the last mile or so. It's better to have the cool air blowing over everything anyway (rather that idle while parked).
WydRyd 05-16-2006 06:00 PM
Ditto! If I've been driving it a bit hard, I just take it easy the last 1-2km's before reaching my final destination and then just turn it off and walk away. Otherwise I just turn it off and not worry about it. I drive my car daily, in traffic, so I don't get that much opportunity to drive it into full boost anyway.
tsuter 05-16-2006 08:15 PM
"That" my friends is a VW afterrun coolant pump thermostated at 95C to pump coolant thru the turbo jacket for 3-5 minutes after motor shutdown. For small turbos having both oil and water fittings like VWs 1.8T Golf, GTi, Turbo Beetle....KO3, KO4 turbos.
Emission 05-16-2006 09:08 PM
Um, where do you find the coolant on a 930? :confused:
rotorhead 05-17-2006 04:47 AM
Another alternative is a turbo After-Oiler
http://www.accusump.com/acc_products/acc_turboiler.htm
RarlyL8 05-17-2006 05:55 AM
Cooling down your turbo is really not a problem for a street car.
The only time you would ever run on boost and immediately shut down is when there are red lights in your rear view. If that is a normal deal for you then you need a timer. :D
bkreigsr 05-17-2006 06:39 AM
tsuter - what's "coolant" ??
tsuter 05-17-2006 06:57 AM
RTFP.....
drophit 05-17-2006 06:58 AM
K thanks
