Jumping Tach
I have a 1970 911 2.0 idle runs good but when I hit high Rpm the tach jumps and breaks down any ideas??? Also the second fuse on fire wall keeps burning out I know I have a short but does this have anything to do with the tach.? Thanks Mark
Old 01-01-2007, 09:13 AM
I'm with Bill
Rick V's Avatar
May want to check the charging system, an over charging alt can cause these problems. Also check all the grounds you can find.
Old 01-01-2007, 09:55 AM
Slumlord
Porsche_monkey's Avatar
Search bouncing tach. Points and voltage regulator are the likely culprits.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 01-01-2007, 11:06 AM
Thanks guys, what about the second fuse what does that control
Thanks again mark
Old 01-01-2007, 11:10 AM
check your points. there getting cooked.
'71 S track car, 2.7L & Webers forever!
Old 01-01-2007, 01:52 PM
Richard Burns's Avatar
Thumbs up
Isn't the tach. on a 70 mechanical (ie Cable drive)?
I would check to see if the inner cable is fraying and catching on the outer casing.
Good luck.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip!
Old 01-01-2007, 02:06 PM
I'm with Bill
Rick V's Avatar
Good luck.
I believe you are thinking of the speedo.
Old 01-01-2007, 02:18 PM
